ᐅ What are common issues when using the Ikea Brimnes furniture?
Created on: 22 Jun 2022 08:37
Rishpetim
I am currently considering purchasing furniture from the Ikea Brimnes series, mainly wardrobes and dressers for my bedroom. However, before buying, I have come across numerous sometimes contradictory reviews online. Specifically, I am interested in common issues when using Ikea Brimnes furniture in everyday life. I am not only thinking about assembly questions but also about durability, material quality, and potential weak points during use. If anyone can share notable difficulties from their own experience, I would be very grateful. What problems occur most frequently, and how can they possibly be avoided or resolved?
baAlejandr23 Jun 2022 13:18Ramon4 schrieb:
Sometimes a thin layer of silicone spray also helps.I can confirm that. Additionally, when loading the Brimnes dressers, it’s important to keep in mind that heavy or unevenly distributed weight can affect the stability of the drawers. Generally, this type of furniture is better suited for lighter items—clothing or light household goods, rather than books or tools.
Another common point of criticism is the assembly of the back panels, which are often secured only with thin nails. Adding extra fixation with screws or standard small nails can improve stability.
If you pay attention to these details, you can avoid the typical problems quite well.
Charles schrieb:
Scratches can easily form on the foil coatingThis is a key issue – the surface is very susceptible to damage, especially if the furniture is frequently moved. I recommend placing protective pads under sensitive items, particularly pieces like dressers.
Additionally, the edges of the Brimnes series cabinets tend to chip or shift with heavy use, resulting in unsightly gaps. These problems are not uncommon for this price range.
Careful and slow assembly is important. Over-tightening screws or forcing parts together can compromise the fit of the components, which may lead to damage over time.
Finally, from my experience, I would say that Brimnes is a type of furniture series you should buy with realistic expectations. That means you get a practical and affordable solution, but not high-end design pieces meant to last a lifetime.
Typical issues I noticed:
- Sensitive surfaces (prone to scratches and wear)
- Hinges and drawer slides that can be somewhat fragile
- Assembly that requires patience and can lead to stability problems if not done properly
Therefore: If you buy Brimnes, allow yourself some time for careful assembly, avoid overloading drawers, and protect the surfaces – then you can enjoy it for a long time. It’s not perfect, but it’s solid for the price. And hey, if a drawer slide acts up, you can often fix it yourself with a little maintenance – that doesn’t take the fun out of the furniture.
