ᐅ What are common mistakes when installing IKEA Platsa sliding doors?
Created on: 17 Jan 2021 09:17
Adam8Hello everyone,
I am currently planning to install IKEA Platsa sliding doors in my new wardrobe and want to avoid potential mistakes. Therefore, I am interested in knowing: What are common errors when installing IKEA Platsa sliding doors?
I would especially appreciate insights on the following points:
- Typical pitfalls during assembly
- Mistakes that can occur when aligning and hanging the sliding doors
- Issues arising from inaccurate measurements or incorrect preparation
- Tips on how to recognize and prevent common errors early on
Experience-based examples are also welcome so that I can get a comprehensive understanding and prepare well. Thank you in advance!
Hi Adam8,
I recently installed the Platsa doors and ran into a few challenges. 😅
- At first, I had trouble aligning the top track properly—it wasn’t perfectly level. Make sure to use a spirit level for this!
- Also, it’s really important that the floor beneath the track is completely flat. I had a slight unevenness, which caused the doors to catch a bit when sliding.
- One thing I underestimated: the rollers of the sliding doors need to be inserted precisely into the tracks. It’s easy to use too much force and bend them.
If you need more details, just ask! But with a bit of patience, it actually goes pretty smoothly. 😊
Hello Adam8,
Your question is very relevant because Platsa sliding doors, due to their modular design, can present some specific challenges. I would like to address the main potential issues and explain the related factors:
- Measurement: A common mistake is not taking precise measurements at the wall and floor. The tracks are often not checked with a second spirit level, so, for example, uneven floors can be overlooked. This often results in doors that hang or are misaligned later on.
- Installation of the tracks: A level and perfectly horizontal surface for the top and bottom tracks is essential. If the bottom track tilts slightly forward or backward, it can cause misalignment of the doors. Drill holes must be made exactly in the correct position; otherwise, the system can become stressed.
- Rollers and adjustment screws: The door rollers have an adjustment mechanism for fine-tuning the height. This step is often forgotten or done imprecisely. It is important to patiently hang each door one at a time and then adjust it carefully.
- Tightening the frame fittings: Sometimes doors are damaged due to incorrect tightening or pressing too hard. Care is needed to ensure that the doors can glide smoothly along the tracks.
Have you already taken measurements and prepared the installation area? The more precise you are here, the fewer problems you will have later.
Hello Adam8,
I would like to share my experiences and offer a brief tutorial on how to avoid common mistakes when installing Platsa sliding doors:
1. Preparation:
- Clear the installation area completely and clean it thoroughly.
- Use a calibrated spirit level for all leveling tasks (especially at the screw points).
2. Measuring:
- Measure the height from floor to ceiling at several points and note the smallest height as your reference to avoid doors not fitting at the end.
- Also measure the width precisely, especially if adjacent walls are not perfectly straight.
3. Track Installation:
- Make sure the tracks are mounted flush and straight. Carefully mark the drilling points for this.
- Check the track multiple times with a spirit level before final fastening.
4. Installing the Rollers:
- Use the adjustment screws on the rollers as instructed when installing. This saves a lot of rework later.
5. Adjustment:
- Hang the doors completely first, then use the adjustment screws individually to level them all to the same height.
A common mistake is to hang the doors quickly and then neglect fine adjustment. This usually becomes a problem after a few days of use.
If you have specific questions, I’m happy to help!
1. Preparation:
2. Measuring:
5. Adjustment:
Additional notes:
- When installing Ikea Platsa sliding doors, be sure to follow the original assembly instructions precisely, as the design is very specific.
- The drill holes must be positioned exactly; small deviations can cause the doors to jam.
- Tip: Avoid over-tightening screws in the particleboard, as this can cause it to tear out.
- Pay attention to the recommended torque for screws, if specified.
- After installation, check the doors several times for smooth operation and any tension.
These points are often the cause of later problems and significantly reduce the functional lifespan.
