I recently purchased an Ikea Platsa wardrobe and am currently assembling it. Unfortunately, some of the original screws supplied with PLATSA are too short or don’t fit optimally for my version or for custom modifications/extensions I want to make using other wood components. Therefore, I’m looking for fastening options and alternatives to the Ikea PLATSA screws that are just as stable and reliable.
I’m interested in hearing which alternatives you have successfully used, what sizes and types of screws are recommended, and if there are any special features I should pay attention to in order to keep the wardrobe sturdy and the connections strong.
So, I’m looking for replacement/alternative screws that are compatible with or better than the original PLATSA screws—ideally regarding pre-drilled holes, thread type, and head design.
I look forward to your experiences and advice!
daalessio3 Oct 2022 11:03The Ikea PLATSA screws are specifically designed to match the wood panels and connectors used, so it is important to compare the exact dimensions and thread pitches when considering alternatives.
A common replacement are fine-thread screws with flat countersunk heads in sizes M4 x 30 mm (1.2 inches) or M4 x 35 mm (1.4 inches), which are often available at hardware stores. It is important that the screw is not too long to avoid damaging the wood and that the head sits flush to ensure the connections are even.
Also, make sure the screws have good tensile and shear strength, as otherwise the structure may become unstable.
For the thread type, metric screws with full threads are especially recommended.
If you have planned special connections with dowels or barrel nuts, combinations of screws with matching nuts or cylinder head screws can be helpful.
Can you measure the exact dimensions of the original screws? That helps to find suitable alternatives.
Hello irissin,
Your concern is easy to understand, especially when you want to extend the PLATSA elements or make custom adjustments.
Here is a brief overview of alternatives you can consider instead of the Ikea screws:
- Cylinder head or flat countersunk screws M4 to M5, length between 25 and 40 mm (1 to 1.5 inches), depending on the thickness of the panels
- Fully threaded screws instead of partially threaded ones, which provide better holding power in particleboard
- Stainless steel screws if you want to avoid moisture or rust
- Alternatively, coarse-thread wood screws for furniture, which do not require a pre-cut thread
Make sure the screw material and thread type are mechanically compatible with the pre-drilled holes and the wood quality! I recommend testing a small quantity before ordering larger amounts.
Hello irissin,
I would like to provide a more detailed explanation about the options for PLATSA screws, as this topic has some nuances.
Basically, Ikea PLATSA cabinets often use screws with flat countersunk heads and a metric fine thread, specifically sized to securely join the particleboard panels without pre-drilling or with minimal pre-drilling. The wood panels are often compressed under pressure to achieve higher stability, which can make screwing in more difficult.
If you are looking for replacements, please consider the following points:
- Diameter and thread pitch must match to ensure load-bearing capacity. The diameter is usually 4 mm (M4) with a pitch of about 0.7 mm (standard metric).
- The length of the screw should correspond to the thickness of the panels being joined. If it is too short, there will be insufficient grip; if it is too long, it can protrude through the material and damage the appearance or function.
- Flat countersunk heads are essential so that the screw can be fully recessed.
- Screws made of hardened steel or stainless steel offer the best stability and durability.
- If you want to use insert nuts, combinations of machine screws M4x20-30 mm (M4x0.8 inches) and insert nuts are an option that provides more expansion possibilities.
For temporary solutions, Torx screws are sometimes recommended because they allow higher torque transmission and reduce slipping.
My tip: If possible, precisely measure the original screws or take them to a specialist store. They can recommend suitable alternatives that match exactly in material and thread.
Sorry if this became a bit lengthy, but the right screw is essential for these systems.
I have put together a short guide on how to choose suitable alternatives to the Ikea PLATSA screws:
1. Determine dimensions: Measure the exact length and diameter of the original screw.
2. Check the screw head: PLATSA usually uses flat countersunk heads because they sit flush with the surface and provide stable fastening.
3. Thread type: A fine metric thread is preferred as it holds better in particleboard.
4. Material: Zinc-plated steel is usually sufficient; use stainless steel for higher humidity environments.
5. Load: Consider the forces acting on the connection (tension, compression, shear).
6. Pilot holes: If holes are already pre-drilled, the diameter must match the screw so the thread engages properly.
7. Testing: Always try screws first on a sample piece.
Randomly replacing screws with others often leads to instability and damage to the furniture.
In summary: M4 flat countersunk screws, 30–35 cm (12–14 inches) long, full thread, and stainless steel are good alternatives. I hope this helps!
bapar schrieb:
If you want to work with threaded inserts, combinations of machine screws M4x20-30 mm (0.16–1.18 inches) and threaded inserts are an option that gives you more flexibility for future modifications.That’s a really good tip! I once had the problem that the screws alone didn’t provide the hold I wanted, and these threaded inserts gave me the flexibility to modify the cabinet later without losing stability.
What I found a bit challenging was the precise alignment when installing the inserts, but with patience it worked perfectly. For anyone with some DIY experience, I can definitely recommend this.
Also, I think when it comes to replacement screws it’s important not only to focus on the dimensions but also to consider the screw material. Rust protection and quality pay off in the long run, especially for furniture that is used or moved frequently.
