ᐅ What alternatives are there to IKEA PLATSA for custom furniture construction?
Created on: 23 Feb 2020 19:17
Mandag
Mandag
23 Feb 2020 19:17
I am currently planning the furniture for a new living room setup and am especially interested in modular cabinet and shelving systems. IKEA Platsa seems to be a popular choice, mainly because of its flexibility and relatively good value for money. However, I have also heard from some sources that there are certain weaknesses regarding Platsa’s stability and assembly.
My question to you is: What alternatives are there to IKEA Platsa for furniture construction that are similarly modular but may offer better quality, customization options, or design? I’m looking for systems that can be easily configured by myself without the result looking too much like a typical home improvement store product.
Important factors for me are durable materials, flexible size adjustment, and modern aesthetics. I am especially interested in experiences with lesser-known manufacturers or brands at a comparable price point that might be a bit higher quality than Platsa.
I look forward to your opinions and recommendations!
kyledeo
23 Feb 2020 20:03
Hi Mandag,
a solid alternative to PLATSA are the systems from Hülsta or USM Haller. These are more expensive but offer better quality and modularity.
If you prefer a more affordable option, take a look at the furniture range from Tojo – also modular and made with high-quality materials.
Additionally, systems like USM allow for good flexibility as they combine plug-in and screw connections.
GEKAU51
24 Feb 2020 09:46
kyledeo schrieb:
A solid alternative to PLATSA are the systems from Hülsta or USM Haller.
Sure, Hülsta and similar brands are great, but they are also quite expensive and often not affordable for the average DIY enthusiast. I wonder why everyone always refers to the usual suspects when looking for alternatives.
The problem with PLATSA is that in Germany, people tend to think too much in terms of prefabricated, modular kit systems. Why not consider custom work from small, local carpenters?
Especially when quality and individuality are desired, bespoke solutions are simply unbeatable – even if they seem more expensive at first glance. The lifespan and effort saved will save you a lot of trouble in the long run.
Additionally:
- Sustainability is often valued higher with carpenter-made furniture
- You get exactly the design you like
- No run-of-the-mill, off-the-shelf standard
In short, PLATSA alternatives in furniture stores are convenient, but going to a carpenter is more worthwhile if you value quality.
laume
24 Feb 2020 12:28
Hello Mandag,
I would like to add to your question and explain how you can approach selecting a suitable system for your needs, as there are very different requirements for furniture pieces.
First, you should consider the intended use of your furniture, including how much weight it needs to support and which modification options make sense.
Second, a combination of modular systems with custom additions from a carpenter or manufacturer can often provide the best solution.
Examples of alternatives to the pure PLATSA system:
- IKEA’s Ivar system, made of solid wood with an open design, which can be individually customized and tends to feel more robust
- EUROKRAFT or SMEDBO with metal grid frames, if stability is critical
- For versatility and durable materials, also the somewhat more craftsmanship-intensive plug-in systems from USM or Tylko
Additionally, many manufacturers offer online configurators to specify exact dimensions and adapt the design.
If you share specific use scenarios (e.g. living space size, weight of items, color scheme), more targeted recommendations can be made.
I hope this helps you for now!
