ᐅ What modifications can I make to BILLY shelves to improve their stability?
Created on: 12 Nov 2022 08:17
PoneloHello everyone, I have a question regarding the Billy shelves from Ikea. I’ve noticed that they seem a bit unstable when subjected to heavier loads or if you shake them firmly. So my question to the community is: What modifications can I make to Billy shelves to significantly improve their stability? I’m interested in both simple solutions that don’t require major alterations and more extensive changes that provide lasting results. Tips on suitable materials or tools for this would also be appreciated. Thanks in advance!
Saramar schrieb:
The easiest way is to fix the shelves to the wall.This is the key point, as BILLY shelves are primarily designed as wall-mounted units. To ensure maximum stability, it is essential to use appropriate wall plugs for the type of wall – for example, expansion anchors for concrete or cavity anchors for drywall.
Additionally, I recommend replacing the back panel with slightly thicker screws – the original nails are quite thin and provide less support. A back panel made of 6 or 8 mm (0.24 or 0.31 inch) plywood can also significantly improve stability if it is replaced or added.
For an even sturdier structure, it is advisable to reinforce the shelves with metal brackets in the corners. Small brackets can be attached to the inner sides of the side panels, which significantly prevent the shelves from bending.
Additionally, it is recommended to secure the shelving unit to the wall not only at the top but also in the middle to prevent it from tipping forward or sideways. A three-point fastening approach is important, especially for large or tall shelving units.
Those with DIY skills might also consider replacing the back panel with a plywood board. This is more stable than the usual thin particleboard and provides greater torsional rigidity. In this case, the panel should be carefully screwed in on all sides.
kulau schrieb:
It is also advisable to secure the shelf not only at the top but also in the middle to the wallInteresting point. But I wonder how effective that is if the wall itself is not continuously stable (for example, drywall). Can one really expect a lasting increase in stability in such cases? Shouldn’t the base of the shelf also be improved, so that wall mounting is not seen as the only solution?
Regarding the base area: I have had good experiences when small non-slip pads are attached under the feet. This prevents slipping on smooth floors and noticeably stabilizes the shelving unit.
Additionally, metal cross braces can be installed at the lower part to reduce wobbling.
