ᐅ Weishaupt (split system) or Kermi (monoblock unit)
Created on: 10 Nov 2019 22:03
M. Gerd
We are currently trying to decide whether to choose a Weishaupt LS 8 air-to-water heat pump as a split unit or to go with a Kermi x-change dynamic ac 8 AW E monoblock instead.
The Kermi is said to be more efficient and can also use solar power "intelligently," but it comes with an extra cost of nearly 5,000. It’s clear that I won’t recover that 5,000 through more efficient operation alone, but maybe the maintenance costs are lower, the air-to-water heat pump is quieter, and so on.
Which option would you lean towards and why? What do you see as the pros and cons of these two units?
Thanks and best regards,
M. Gerd
M. Gerd
13 Nov 2019 21:49
I don’t know how Kermi compares in price to Zehnder, as we haven’t received an offer yet. My heating installer suggested contacting the field service representative to see if there’s any possibility of a discount if we buy both units from Kermi. The entire underfloor heating system, including the pipes, will also be installed by Kermi. Hopefully, something can be arranged because we would really prefer Kermi, mainly due to the noise level. We are somewhat concerned that the split system might be noisy.
How is it exactly? I understand that the split system is supposed to be relatively loud, but does that only apply to the outdoor unit, or the indoor unit as well?
We are located near Frankfurt am Main, specifically north of Hanau.
schaaaf
13 Jul 2022 11:42
Hi, what is the current status of the Kermi X-Change Monoblock? We are about to place an order for it in our new build and I wanted to know if the system causes any issues or if its efficiency is still good.
Alhtk24
20 Aug 2025 21:59
Grantlhaua schrieb:
I’m located not far from the Kermi headquarters, and the IDM would have cost me almost the same as Kermi. I didn’t consider anything else because I value quality and also a bit of the design. I also visited the heat pump directly at Kermi’s factory.
Why would the pipe freeze in winter? We installed a district heating pipe here, and the connections are insulated again, then covered with this aluminum cap. So nothing should freeze. I also bought the X-Center Base and the Kermi actuators/room thermostats. Plus the Kermi central ventilation system, so everything is integrated into one system.
I can’t say yet how maintenance-intensive Kermi is, since it has only been running for 3 weeks…
Hopefully, I’ll finally get my meters soon, so the photovoltaic system can be connected to the grid…
M. Gerd schrieb:
We are currently deciding whether to go for a Weishaupt LS 8 air-to-water heat pump as a split unit, or rather choose a Kermi x-change dynamic ac 8 AW E as a monoblock.
The Kermi is supposed to be more efficient and also able to "intelligently" use solar power, but it comes with a surcharge of nearly 5,000. It’s clear that I won’t recover the 5,000 through efficient operation alone, but maybe the maintenance costs are lower, the air-to-water heat pump is quieter, etc.
Which would you lean towards and why? In your opinion, what are the pros and cons of the two units?
M.G.
After about 6 years, are you satisfied with your systems? My heating contractor recommended a ventilation system from Kermi. I personally tend to prefer Zehnder. I would appreciate your feedback.
