ᐅ ETICS EPS vs. Mineral Wool
Created on: 22 Nov 2025 08:08
Markusba
Markusba
22 Nov 2025 08:08
we are currently deciding on the wall construction for our bungalow, considering cost, thermal insulation, and soundproofing (possibly also vapor permeability).
I am looking at two options:
[TH][/TH]
[TH]1) StoTherm Classic®[/TH]
[TH]2) StoTherm Mineral[[/TH]
Base layer Poroton-Planziegel-T14-24.0 cm (9.4 inches) L (load-bearing substrate) Poroton-Planziegel-T14-24.0 cm (9.4 inches) L (load-bearing substrate)
Insulation layer Insulation boards Sto-EPS Insulation board Polar II 032 NF (20 cm / 8 inches) bonded with StoLevell Uni Insulation boards Sto-mineral wool board 2/B/H4 W5 (20 cm / 8 inches) bonded with StoLevell Uni
Base coat StoArmat Classic plus F/M/G with reinforcement layer: Sto fiberglass mesh StoArmat Classic plus F/M/G with reinforcement layer: Sto fiberglass mesh
Intermediate coat ]StoPrep Isol Q
Top coat StoSilco® K/R/MP StoSilco® K/R/MP
[TH][/TH]
[TH]1) EPS (EPS Insulation board Polar II 032 NF[/TH]
[TH]2) Mineral wool (Mineral wool board 2/B/H4 W5)[/TH]
Thermal insulation U-value (W/(m²K)) 0.121 0.130
Soundproofing - -
Vapor permeability - ]+ ?however, it is coated?
Cost + + approx. 20%[
Additionally, the roof will be insulated with ISOVER Integra ZKF 1 - 031 between-rafter fleece, 40 cm (16 inches) thick, and equipped with a vapor retarder (ISOVER Vario® Xtra Safe), designed as a cold roof. We will probably install a central ventilation system, but it should also ensure a good indoor climate without mechanical ventilation.
One more note: With the mineral wool option, the detailing of the base of the wall (plinth) is naturally a bit more challenging. Or is it also possible to align the mineral wool insulation boards flush with XPS/plinth insulation boards using a reinforcement mesh, as shown in the Sto detail?
Are there any opinions on this topic in the forum?
Thanks in advance.
nordanney
22 Nov 2025 08:17
- Use what the company installs
- Mineral wool is about 20% more expensive
- Mineral wool is slightly more difficult to work with
- The type of insulation makes exactly zero difference to the apartment
- Both are still classified as special waste
My choice: EPS, which offers absolutely no benefits compared to mineral wool
P.S. The indoor climate is the same regardless of the wall construction. Without ventilation, you will always have a noticeable stale smell (for proof, buy some air quality meters later). So, install controlled mechanical ventilation
