ᐅ Waterproofing membrane or bitumen sheet?
Created on: 7 Jul 2016 19:58
Laureus
we are about to pour the screed. Now the question is whether to install the waterproofing membrane or polyethylene sheeting. The screed thickness is 16cm (6 inches). Which option makes more sense?
Uwe828 Jul 2016 14:18
We installed the Katja flooring ourselves in the basement; it’s not particularly difficult, you just need plenty of utility knife blades. Reason: the basement contractor recommended that we do it ourselves. It wasn’t a lot of work, and the costs were reasonable.
Laureus8 Jul 2016 14:20
Was the foil not damaged by the workers (electrician/heating installer, etc.)? It is so thin...
One008 Jul 2016 15:05
You want to install a membrane for thermal insulation? That must be some impressive membrane...
Or am I missing something (condensation, etc.)?
Anyway. If someone told you that you will get 16cm (6.3 inches) of screed on top of the membrane / waterproofing layer, they most likely mean insulation plus screed.
Laureus8 Jul 2016 15:11
I have seen that there is a foil with an aluminum layer. I assume this is also intended for thermal insulation. Please be kind to me;
•1: I am a woman
•2: I have never built a house before
Uwe828 Jul 2016 15:18
It’s not really thin and can withstand quite a bit.
Laureus9 Jul 2016 18:29
That wasn’t the question; it’s just about whether torch-on vapor barrier or Katja foil is better. Today we installed the torch-on version. Thanks to you all!
