I have noticed some water stains on my IKEA KALLAX shelf for a while now, which don’t come off easily despite careful cleaning. The shelf is in the living room, a typical area where occasional water rings appear, possibly caused by spilled glasses. I am especially interested in effective and gentle methods or home remedies for removing water stains on the original white-coated KALLAX surfaces.
I want to avoid damaging the surface, roughening the finish, or causing discoloration. Has anyone experienced this issue and can share tips on suitable cleaning products or home remedies?
I’m looking forward to hearing your recommended approaches, thanks in advance!
Good morning everyone,
I would like to discuss the topic in more technical detail, especially regarding the material properties of KALLAX surfaces.
KALLAX is usually made from wood-based panels coated with a melamine resin layer. While this coating is resistant to moisture, it is not resistant to lime deposits caused by evaporating water that leaves behind minerals – these are the visible stains.
The key point in removal is to dissolve the mineral residues without damaging the melamine surface. For this reason, I would advise against using highly concentrated acids (e.g., pure acetic acid or lemon acid at cleaning strength).
A gentler approach:
- Dilute vinegar essence with plenty of water (at least 1:10) on a cloth, then rub the spot and immediately wipe with a damp cloth.
- Afterwards, thoroughly wipe the surface with plenty of water to remove any residues.
It is also interesting that some users quickly remove stains with microfiber cloths combined with special cleaning additives – for stubborn stains, a plastic polish can restore the shine.
Could you please clarify whether your KALLAX is affected on the inside (such as shelves) or on the surface? And was the stain caused by water that remained wet or by evaporated water?
A gentler approach:
RAGUGI schrieb:
Spray diluted vinegar solution 1:5, let it sit brieflyI would like to point out that spraying on a melamine-coated surface can be somewhat risky, as liquids should ideally not come into contact with the surface in large amounts to prevent penetration.
Therefore, I recommend applying the vinegar solution onto a microfiber cloth and gently wiping the surface instead of spraying directly. This way, you have better control over the moisture and protect the panels.
Does anyone have opposing views on this?
theo63 schrieb:
Apply the vinegar solution onto a microfiber cloth and gently rub the surface, instead of spraying it directlyThat really sounds sensible! I probably would have sprayed it directly myself, which in the past has caused slight roughening of the surface.
Also: Uspe31, how important is visual perfection to you? If the stain is barely visible, I would sometimes say: Better to be cautious and avoid too many attempts.
Sometimes it’s worth letting stains fade over time; this has worked well for me without damaging the surface.
