ᐅ Water on the Building Site – Does It Cause Problems?
Created on: 30 Dec 2017 23:12
steija1
steija1
30 Dec 2017 23:12
Good evening everyone,
We bought our plot of land a month ago. Since then, I have visited several times to check the water situation, but there has been little change. This worries me a bit; however, the architect seems relaxed and says the house will be built at a higher level during the groundworks anyway. Will this solve my problems?
Location: Our plot is in a newly developed residential area (a geotechnical survey was available before purchase and reviewed by the architect). It is at the end of a cul-de-sac (3 lots in total on this cul-de-sac, 115 in the whole development). Being the last in the cul-de-sac, our plot is also the lowest point, about 0.5 m (20 inches) lower than the first according to the site plan.
Now water is collecting exactly where the house is supposed to be built. 🙁
Is this due to soil compaction from the development? Does no water really drain away? It has been a small pond for several weeks.
I would really appreciate any experiences and feedback.
Good luck,
Jan
Construction site with muddy ground, puddles and leafless trees behind a fence
Building plot with unpaved terrain, puddles, fence and trees in the background
Neighbors without water
Exposed building area with soil and gravel, a white car on the left, fence and trees in the background.
Clear site plan with plots, road layout and trees.
Site plan of a building plot with parcels, road layout and markings.
Baumfachmann
31 Dec 2017 00:08
Don’t worry, it’s reasonable to raise the house a bit. We have an additional 30cm (12 inches) of washed gravel under the foundation slab. Ask the architect.
But a small pond like that is no problem at all.
Domski
31 Dec 2017 08:41
And please don’t forget the drainage around the house at the end, that way nothing will happen there.
kaho67431 Dec 2017 08:57
I don’t see any issues with the house.
I’m more interested in what the soil survey says. Has any fill been added, and if so, what kind? If it is truly natural soil and doesn’t drain well, you would have to expect clay, a low water table, or something similar, which could be problematic for setting up the garden.
Nordlys
31 Dec 2017 10:43
What do I see? The compaction is high. The soil lacks structure? Surface is covered with silty deposits, prone to siltation and forming ponds? I suspect clay layers deeper down. Is that correct?
Solution: Improve soil structure. If the pond disappears, have the soil tilled. Introducing air into the soil. Plowing would be even better, or manually digging over the soil instead of tilling.
Drainage will be necessary. An earth berm towards the higher neighboring property as well. Otherwise, suitable for building. Karsten
Alex85
31 Dec 2017 11:00
This is displaced, compacted ground. It is quite normal for water to accumulate there.
To address the depression itself, the house will need to be built at a higher level, and attention will need to be paid to the external drainage, as has already been mentioned.
