ᐅ Domestic hot water production
Created on: 5 May 2014 11:36
mamido
mamido
5 May 2014 11:36
Hello!
Since my heating system is currently being installed, I am facing a choice.
Either a buffer tank with an integrated domestic hot water tank or a buffer tank combined with a fresh water system. What would you recommend?
The details:
The house is a new build.
Heating is provided by an air-source heat pump and a hydronic masonry stove.
The buffer tank has a capacity of 1000 liters (264 gallons), and the domestic hot water tank should be 200 liters (53 gallons).
I would appreciate your experience or opinion.
€uro
5 May 2014 12:28
mamido schrieb:
...Since my heating system is currently being installed, I am facing this choice....
An extremely late moment to ask this fundamental question! => general guessing!
Enjoy this overall construction! You seem to have a substantial budget to use such a solution with low energy efficiency in the long run!
mamido
5 May 2014 13:19
€uro schrieb:
A very belated time to ask this basic question! => general guessing game!
Good luck with this overall design! You seem to have a considerable budget to plan to use such a solution with poor energy efficiency in the long term!
Regards
What do you mean by that?
What would you suggest as better?
I can criticize anything right away.
€uro
5 May 2014 13:38
mamido schrieb:
What do you think would be better??
Early assessment of the basics, planning, and sizing by an independent HVAC engineer not tied to sales! Apparently, you “saved” a few euros, but now you have to live with the results in the long term. Whether this is economically beneficial for you overall, you will find out, for example, if heat meters are installed. Usually, this leads to complete disillusionment! A pity for the initially high investment!
mamido schrieb:
..I can criticize anything right away
What is your objective!? ;-)
fire26lars
8 May 2014 21:07
Hello €uro,
what determines the costs for proper planning by an MEP engineer, and what kind of amounts are we talking about for a typical single-family house?
Regards, Lars
€uro
9 May 2014 08:01
fire26lars schrieb:
....what determines the costs for proper planning by an MEP engineer...
First, the term "proper planning" needs to be defined.
Normally, this refers to the HOAI along with all associated content and standards.
In my opinion, for a single-family house, this is far too expensive. Also, most MEP firms are structurally geared towards "larger projects" and usually lack sufficient experience in the "smaller scale" sector. There are significant differences between a hotel complex or commercial building and a single-family house!
For single-family houses, it is entirely sufficient to address the most essential problem areas and to provide the system installer with the technical parameters to be adhered to, without completely restricting their design flexibility.
fire26lars schrieb:
....and what kind of sums are we talking about for a standard single-family house?...
This always depends on the specific individual case. Key factors include the building geometry and the agreed scope of services.
I always provide a detailed offer, even if it requires substantial effort. So, no flat-rate mass business at bargain prices.
Best regards.
