ᐅ Wood-burning stove with water heating in new construction – yes or no?
Created on: 12 Jan 2020 11:06
DerToni
I was a bit surprised that I couldn’t find a fairly recent discussion on this topic (if I missed something and unnecessarily started a new thread, I apologize).
To the main topic:
We are building a new house (solid construction, no special insulation properties) that will be heated with a heat pump.
A wood-burning stove is planned for the living room, and now we face the question: should it be hydronic (water-heated) or not?
I initially approached this with the firm belief, “of course hydronic, why not, this way the stove can also be used to supply domestic hot water and central heating.” However, feedback from the first stove installers has made me somewhat doubtful (“the extra costs are hardly compensated by the energy saved,” and so on). Therefore, I thought I’d ask here for experiences from other homeowners on this subject.
So, as the title says, hydronic wood stove in a new build – yes or no? I would really appreciate some opinions and experiences.
DerToni
DerToni
12 Jan 2020 20:27
Thank you all very much, this helps me a lot!
ludwig88sta
13 Jan 2020 10:37
I can confirm what has been written so far. That’s also what I was told.
At first, I thought, “That sounds great, supporting the heating system, especially in winter when you light your fireplace more often.” But the cost, effort, and cleaning clearly make it uneconomical.
When choosing a fireplace, you should also consider that it is not too powerful (especially in modern, well-insulated houses with underfloor heating or similar). As has been mentioned here several times, every component (heat pump and also the stove) should be well matched to the house’s (energy) demand.
fragg
13 Jan 2020 10:45
Just as an idea, with temperatures just below zero, I have at least 19°C (66°F) in every room of my 300m² (3,229 ft²) house when the stove in the living room is blazing. Even after two weeks.
Condition: the living room is then at 26°C (79°F)... the rest is regulated by the controlled ventilation system with heat recovery.
ludwig88sta
13 Jan 2020 10:47
Yes, but basically I already find 26°C (79°F) almost too warm.
fragg
13 Jan 2020 12:24
ludwig88sta schrieb:
yes, but basically I find 26°C (79°F) almost too warm
actually, that was a comfortable warmth. Even guests were surprised when they saw 26°C (79°F) on the thermometer and said it was way too warm. Until then, they had found it pleasant...
ludwig88sta
13 Jan 2020 12:36
Yes, that is certainly possible. What type of stove do you have and in what kind of house? Water-heated? How much thermal mass for heat storage?
