ᐅ Noise from the washing machine heard throughout the house due to the laundry chute?
Created on: 24 Feb 2018 21:54
Pedii
Pedii
24 Feb 2018 21:54
What are your experiences with a laundry chute? The laundry chute ends in the utility room. Does this mean that the noise from the washing machine can be heard throughout the house?
Thank you very much for your feedback!
Knallkörper
24 Feb 2018 21:56
Yes, that’s correct. Our laundry chute is therefore made from a tubular sound damper by the company Torx.
blackm8824 Feb 2018 22:00
We have a laundry chute from the bathroom on the upper floor to the utility room in the basement. It passes through the ground floor (pantry).
Our chute is a PVC pipe with a diameter of 30cm (12 inches). The pipe ends between the heat pump and the washing machine, with the dryer next to it.
In the bathroom, we made a cover out of wood and tiled it. On the underside, I attached a 5mm (0.2 inch) rubber insulation mat. We don’t hear anything in the bathroom. It would have worked without insulation, but then the cover would slam when dropped.
merlin83
24 Feb 2018 22:28
blackm88 schrieb:
We have a laundry chute from the bathroom on the upper floor down to the utility room in the basement. It passes through the ground floor (pantry).
Our chute is made from a soil pipe with a diameter of 30cm (12 inches). The pipe ends between the heat pump and the washing machine, with the dryer next to it.
In the bathroom, we built a wooden cover that we then tiled. On the underside, I attached a 5mm (0.2 inch) rubber insulation mat. We don’t hear anything in the bathroom. It would have worked without the insulation as well, but then the cover makes noise if you drop it.
Same construction here. We don’t have any noise issues.
