I’m planning to design my wardrobe based on an IKEA KALLAX shelving unit because I appreciate its modular design and value for money. However, in my initial attempts, I noticed that the modules – especially when used freestanding or as room dividers – can feel somewhat “loose” and not as stable as I would like for a wardrobe. Specifically, I’m concerned about the rigidity and stability of the structure so that clothes, jackets, and accessories can hang or rest securely without the unit wobbling or warping.
Does anyone have experience with this and can offer advice on how to prevent or reduce this “looseness” in a KALLAX framework when used as a wardrobe solution? I would appreciate suggestions for reinforcements, fastenings, or practical additions that are particularly suitable for use as a wardrobe with heavier textiles.
Nabla64 schrieb:
More stable back panel, use screws instead of just fitting parts together, bracing and securing at the floor/ceilingThanks for the detailed explanation, that sounds like a clear approach. I hadn’t even considered replacing the back panel, I thought the original panel would be enough – but reinforcing it definitely makes sense.
Dilen schrieb:
What is the planned load? Is the coat rack free-standing or placed in a corner?Regarding the load again: heavy winter jackets will hang in the upper compartments, with some larger bags underneath. The coat rack is free-standing as a room divider, so it will be accessible from both sides. Securing it to the floor or ceiling is not planned at the moment, and I would prefer to avoid that if possible.
Do you have any advice on whether additional reinforcements (other than back panels) are necessary for a free-standing structure? Or are the reinforcements alone sufficient?
From a technical perspective, there are two main challenges to address with freestanding KALLAX wardrobe units: lateral twisting and stability under load.
1. Replace the back panels with multiplex boards at least 6 mm (1/4 inch) thick, as previously mentioned. This increases torsional rigidity.
2. For room dividers, installing diagonal wooden battens on the back is recommended, such as cross-bracing reinforcements, to prevent lateral shifting.
3. The connection of individual modules using visible or concealed connector screws should be done thoroughly.
4. Even if floor and ceiling fixings are not desired, heavy loads are only safely supported if the base is sufficiently wide and slip-resistant. Supporting the unit with non-slip pads can prevent it from tipping under load.
5. Sturdy steel profiles or rails can potentially be used to reinforce horizontal levels. However, this often means moving away from IKEA’s standard solution.
Note: The heavier and bulkier the items stored in the wardrobe, the more important these reinforcements become.
Marcellela7 Sep 2024 07:59Ensure that the modules are level and connected with screws, then reinforce the back panel. If you do not want to fix the unit to the ceiling, make the floor slip-resistant and consider using appropriate base plates.
This is more than sufficient, especially for freestanding wardrobe units where stability is important.
Fitigu schrieb:
For room dividers, it is recommended to install diagonal wooden slats on the back sideThat sounds like an elegant solution. Is there a preferred type of wood or cross section for the diagonal braces? And what is the best method to fasten them? Screws or glue?
It is important to me that the solution does not become too heavy, as the room divider will be moved occasionally.
If possible, I would like to keep the modifications as minimal and reversible as possible.
velina schrieb:
Is there a preferred type of wood or cross-section for the diagonal braces? And what is the best way to attach them?For use as a freestanding room divider, it makes sense to choose lightweight but sturdy wood, such as spruce or pine, with a cross-section of 20x30 mm (about 1x1.2 inches) or 30x30 mm (about 1.2x1.2 inches).
You should attach the braces with wood screws, ideally on the inner sides of the back of the shelving unit, underneath the previously installed MDF panel. Glue alone is not suitable for this kind of load because lateral forces can cause it to come loose. Screw connections are reversible and can be quickly removed if needed.
In addition to installing the diagonal braces, you can also reinforce the lower corners with small metal brackets and screws to provide extra stability in the corner areas.
It is important to install the braces tightly, with no play, so the shelving unit does not flex.
If you plan to move your room divider occasionally, it’s advisable not to screw the screws in too deeply to allow for easier disassembly.
Feel free to ask if you want more details.
