ᐅ Applying wallpaper inside distribution boxes / junction boxes
Created on: 22 Feb 2017 09:10
jan2110Hello,
during our renovation, we reused existing junction boxes. On the ground floor, the walls were plastered, sanded, and then painted. The boxes were closed with spring-loaded covers. It doesn't look very neat, but it’s not very noticeable unless you look closely.
Upstairs, wallpaper will be applied everywhere. It’s non-woven wallpaper that can be easily removed and repositioned. Do the junction boxes need to be additionally covered with lids? Or can they simply be wallpapered over?
If I install a lid now, it will probably protrude about 1cm (0.4 inches) from the wall and show through the wallpaper because the spring mechanism doesn’t hold properly.
On one wall, I removed the springs, glued the cover on, and then wallpapered over it. Would it be okay to just wallpaper over the boxes, or are there any risks involved?
What other options are there?
I realize it might have been better to use deeper switch boxes, but now it’s done and I have to live with it.
Jan
Jan
Bieber081522 Feb 2017 09:31jan2110 schrieb:
What other options are there? Switch frames and blank covers from your electrical series could also be considered.
Gartenfreund24 Feb 2017 06:13Yes, junction boxes must be closed with a cover.
So, 1 cm (0.4 inches) will definitely not bulge out. If it does, the cover will also protrude accordingly. If you want a smoother finish, you can scrape off the plaster around the junction box to the thickness of the cover. This way, you can somewhat recess the cover and the wall will be even.
There are several reasons why the springs on the cover might not catch. Either the junction box is so full that the springs simply have no space left. Try to create some room. Additionally, it could be that you simply have the wrong cover.
At the end, you suddenly mention switch boxes. Since switch boxes and junction boxes are two different things, I wonder what you actually installed. Or was that just a typo?
