ᐅ Wall Thicknesses in Timber Frame Construction – Interior Walls and Exterior Walls?
Created on: 4 Nov 2018 13:15
AlyssaAnn
AlyssaAnn
4 Nov 2018 13:15
Good day.
What are the typical thicknesses for exterior walls, load-bearing interior walls, and non-load-bearing interior walls in timber frame construction (energy saving regulation standard)?
We are planning to build an urban villa, and until then, I would like to create my own floor plan. For this, I want to have an approximate idea of the wall thicknesses I need to work with. I understand that there are certainly many options, but what are the most common wall thicknesses?
Best regards.
haydee
4 Nov 2018 13:18
Take a look at the construction specifications provided by house manufacturers, for example Schwörerhaus, Weberhaus, Rensch-Haus.
blackm884 Nov 2018 13:49
For a good exterior wall, plan for about 38-44 cm (15-17 inches). Interior walls can vary depending on the structural requirements. Usually, they are at least 12 cm (5 inches), or 18-24 cm (7-10 inches) for load-bearing walls.
AlyssaAnn
4 Nov 2018 13:53
Thank you very much for the responses.
11ant4 Nov 2018 21:24
AlyssaAnn schrieb:
What thickness are exterior walls, load-bearing and non-load-bearing interior walls in timber frame construction (Energy Saving Ordinance standard)?
Don’t make it too complicated as a layperson, especially since it’s hard to know exactly where load-bearing walls should be. As a general rule, plan for 40cm (16 inches) exterior walls and 20cm (8 inches) interior walls. Be careful not to add just a few centimeters for fitting a specific piece of furniture. This way, you’ll have a solid basis to continue working from.
5 Nov 2018 00:02
Don’t make it too complicated as a layperson, especially since it’s hard to know exactly where load-bearing walls “belong.” Generally plan with 40 cm (16 inches) for exterior walls and 20 cm (8 inches) for interior walls (and be careful not to add just a few centimeters here and there to fit a specific cabinet). That way, you’ll end up with something you can work with.
I’d do it similarly.
Timber frame construction is slimmer than solid walls. For exterior walls with just plaster, I’d go with 34 cm (13 inches) and 15 cm (6 inches) for interior walls. There are no load-bearing walls, but necessary studs are integrated within the interior walls. Allowing some clearance everywhere is important when planning yourself. After all, you usually don’t place furniture directly against the wall, so there should be some space between. And 5 cm (2 inches) too much is better than 5 cm (2 inches) too little.
However, a word of caution: many prefab home manufacturers don’t allow many changes to their standard floor plans. So the contractor should already be decided, and the preferred design should be only slightly modified.
