ᐅ Wall Shelf for Pantry: What Is Strong Enough?
Created on: 14 Mar 2021 08:10
freisinger
freisinger
14 Mar 2021 08:10
I would like to ask for your experience with wall shelves. We have a timber frame house. The walls are covered with gypsum fiberboard. I want to build a shelf in the pantry myself using furniture-grade panels. Yesterday, I got the boards and also wanted to get the shelves. The simple wall rails available at the hardware store seemed very unstable to me. Which ones have you installed or would you recommend?
Nice-Nofret
14 Mar 2021 13:55
Seriously? Build it yourself when there are affordable ready-made systems available? Depending on what you need to store, a heavy-duty shelving unit might be the right choice.
freisinger
14 Mar 2021 16:00
Of course. I need dimensions that are not available for purchase as standard.
14 Mar 2021 20:04
freisinger schrieb:
Of course. I need dimensions that are not available off the shelf.
Can’t you use Ivar? It doesn’t have to be custom-made.
debaser15 Mar 2021 16:40
I would definitely recommend the simple shelving rails from the hardware store 😀
I have them in my pantry as well, and they’re definitely sturdy enough for that. You can also just use a few extra rails if you’re worried it won’t hold.
BBaumeister
15 Mar 2021 16:48
Otherwise, simply use wooden beams as supports and then attach the shelves to them with metal brackets. If it is a shelf that spans from one wall to the other, you can also use beams running across and secure them with joist hangers.
