we are currently cutting channels for the electrical wiring on the ground floor.
For our calcium silicate bricks, we are using a Bosch GNF 20 CA wall chase cutter with two inserted cutting discs and spacers.
The chasing works reasonably well, but chiseling out the channels afterwards is quite time-consuming and tedious.
Is it possible to use wider cutting discs (e.g., 9.5mm (3/8 inch) slot cutters) in this type of wall chase cutter to get finished channels?
Or is more power required for that?
Good luck
Good luck
