ᐅ Wall construction: which material is best for sound insulation? Calcium silicate brick?
Created on: 4 Apr 2016 14:18
bf-therockB
bf-therock4 Apr 2016 14:18Hello forum,
I am currently looking for the right wall construction for our house.
- The building is located near a railway line.
- It will have a brick veneer.
I am leaning towards autoclaved aerated concrete (AAC) for the walls. However, from what I have read online, these are not very effective for sound insulation. I would like to hear your opinions on this, especially regarding a location close to a railway track.
My proposed wall assembly from outside to inside:
Outside air
10 cm (4 inches) brick veneer
2.4 cm (1 inch) air gap
6 cm (2.5 inches) insulation
26 cm (10 inches) autoclaved aerated concrete (if available in this thickness)
approximately 1.5 cm (0.6 inches) plaster
Inside air
So, what do you think about this?
What type of insulation would you recommend?
Should the interior walls be built with calcium silicate bricks to reduce noise transmission from adjacent rooms?
Thanks and regards
Rock
Outside air
Inside air
Thanks and regards
Rock
bf-therock6 Apr 2016 22:48no one has an opinion
Irgendwoabaier6 Apr 2016 23:05bf-therock schrieb:
niemand eine MeinungOf course not. Especially topics like sound insulation need to be planned consistently; focusing solely on wall constructions is simply unreasonable. It’s better to approach the whole issue holistically, consider it during planning, and if necessary, include the exterior landscaping in the planning as well. Anything else leads to poor results.
bf-therock schrieb:
- Building close to a railway line.How is the proximity defined? 50 meters (165 feet) or perhaps 500 meters (1,640 feet)?
