ᐅ Wall opening, reveal repair, plaster or base coat plaster
Created on: 22 May 2025 12:17
Motero1
We made an opening in a double-wythe brick wall to install a door.
To repair and plaster the reveal, which type of plaster should I use?
Standard plaster or base plaster?
The wall is at ground level and not protected from rain. Layer thicknesses are 1-10cm (0.4-4 inches).
Motero1
26 May 2025 20:09
Teimo1988 schrieb:
Is the door already installed?
No, that is the old insulation, which will be removed completely once the door is installed.
No trims will be applied there; the area needs to be plastered and painted in the same color.
Teimo1988
26 May 2025 22:56
Isn't that an opening to the outside? Exterior doors and windows are usually finished with plaster beads. At the floor level, you need to seal it with liquid waterproofing, for example. If I were you, I would do some research instead of just slapping plaster on there.
Motero1
27 May 2025 00:17
Teimo1988 schrieb:
You need to waterproof the floor, for example with liquid plastic.
That is known. Thanks for the tip anyway.
Teimo1988 schrieb:
If I were you, I would do some research on that.
Well, that’s exactly why I’m here.
