ᐅ Wall Opening/Demolition of a Non-Load-Bearing Wall – What to Consider?
Created on: 11 Mar 2016 12:07
Kailies
Kailies
11 Mar 2016 12:07
We would like to completely remove a non-load-bearing wall (which has been checked by a structural engineer) between the living room and the kitchen, see the picture.
The following preparations have been made: a container for debris has been arranged, masks and other protective gear are available, plastic sheeting for covering has been obtained, and a Hilti rotary hammer, sledgehammer, hammer, and chisel are ready for use.
My question is whether we as non-professionals can just start hammering away, or is there anything in particular to watch out for (especially at the sides and ceiling)? A lintel shouldn't be necessary for a non-load-bearing wall, right? We will turn off the power beforehand since there are still outlets and light switches in the wall.
Maybe someone here has already removed a wall and has some tips for us?
Thank you in advance!
Kailies
Empty living room with light-colored walls, parquet floor, and open door to the adjacent room
Z
zod
11 Mar 2016 13:53
What type of wall is it? (Masonry, drywall, etc.) This way, it might be possible to create a clean break edge using a large stone-cutting angle grinder.
If it is masonry, a large sledgehammer is usually sufficient to demolish the wall.
Kailies
11 Mar 2016 14:21
Hello and thank you for your reply!
I already made a test hole in the wall, see attachment. I am not familiar with the material—how should I proceed here?
Good luck
Hole in wall plaster with rough mortar and broken edges – indication of construction defect in the wall
wrobel11 Mar 2016 18:56
Hello
If the wall is non-load-bearing and also not bracing,
I would completely cut through the connections with a cut and break method to avoid damage to
the walls that will remain in place.
Then proceed as planned with the large hammer.
Olli
Oh yes..... You should know in advance what is planned for the existing floor and act accordingly.
Kailies
12 Mar 2016 16:31
Hello and thank you for the responses.
Since there is currently no "Cut n Break" tool available, we will first remove the inside of the wall using the mentioned tools. We will need to get additional tools for the transitions.
The tiles in the kitchen will be removed, and the parquet flooring will be taken out to a depth of 1 meter (3.3 feet). However, we have carefully covered the parquet again using boards, cardboard, and OSB panels. An industrial vacuum cleaner is ready to help reduce the dust somewhat.
I will upload a photo once we are done...
Kailies
13 Mar 2016 15:30
So... the wall is removed. The friendly neighbors even let us work on Sunday. The debris will still be cleared away.
It was easier than expected with the Hilti and a 5 kg (11 lb) hammer.
Thanks again for the feedback.
Wohnraum im Umbau mit Trümmern, Leiter, Fenster und Heizkörper
