ᐅ Vinyl Flooring: Should It Only Be Glued When Used Over Underfloor Heating?
Created on: 10 Jul 2017 15:51
Hendrik007
I was a bit surprised when a professional (hammer) told me today that vinyl flooring on underfloor heating should definitely be glued down, otherwise the heat transfer would not be sufficient.
Is this a common opinion among you as well?
readytorumble
11 Jul 2017 13:32
For us, the material costs were basically the same. However, in my opinion, the gluing cannot just be done by yourself, so you have to pay for the labor. On the other hand, the click system flooring can be installed quite easily as a DIY project.
Labor costs were about 22 euros per m² (approximately 2.05 USD per ft²), including baseboards.
Sascha_aus_H11 Jul 2017 13:48
If you have it installed, there was not much difference for us.
The glued vinyl was 5€ per square meter (approx. 5.5 USD per square yard) cheaper than the click-lock version.
We paid 10€ net per square meter (approx. 11 USD per square yard) for installation (same for both options), but for the glued vinyl, we also paid 5€ per square meter (approx. 5.5 USD per square yard) for the additional floor structure (height adjustment due to tiles).
77.willo11 Jul 2017 17:28
We found glued vinyl to be more affordable. The material was 20 euros more expensive, but installation was 25 euros cheaper. However, there were a few additional euros for the screed heightening.
DerZert
12 Jul 2017 12:00
We are currently in the process of selecting designer or bio-based flooring. The question often comes up about which installation method is better: glueing or clicking.
The new floors, for example from Wineo, have a thickness of 9mm (3/8 inch) and include integrated sound insulation.
I find it hard to understand how a glued layer that is only 1mm (0.04 inch) thick could be of higher quality than a 9mm (3/8 inch) floor with the appropriate HDF core layer, and so on.
Could someone help me with this? By the way, we do not have underfloor heating!
Hendrik007
12 Jul 2017 12:25
What exactly are bio floors?
The total thickness of the vinyl floors we compared—whether glued or click-lock—was consistently between 5-6mm (0.2-0.24 inches).
77.willo12 Jul 2017 12:28
The only relevant factor is the thickness of the wear layer. The rest consists of the substrate layer with the click system and insulation. You don’t need either of these with the glued option.
