ᐅ Vinyl in the Bathroom – Waterproofing – Timber Frame Construction
Created on: 5 Jan 2017 06:54
world-e
world-e
5 Jan 2017 06:54
how does it work in timber frame construction when installing moisture-resistant (click) vinyl flooring in the bathroom and a full waterproofing system (liquid sealant, waterproof membranes, sealed corners, etc.) is applied? The waterproofing won’t be perfectly flat to lay vinyl on, right? Or can an impact sound insulation underlayment even out these irregularities? Or does the vinyl then need to be fully glued down?
Thanks
stefanc84
14 Apr 2017 01:50
world-e schrieb:
how is it handled in timber frame construction when installing moisture-resistant (click) vinyl flooring in the bathroom, and a full waterproofing system (liquid membrane, waterproof sheets, sealed corners, etc.) is applied? The waterproofing probably won’t be perfectly flat for laying vinyl on, right? Or can an impact sound insulation layer compensate for these unevenness? Or does the vinyl need to be glued down in that case?
Thanks
I’m also interested. How have you solved this?
Knallkörper
15 Apr 2017 10:15
is the waterproofing in your case more than just a coating? Do you have screed in the bathroom?
stefanc84
15 Apr 2017 13:14
Knallkörper schrieb:
is the waterproofing for you more than just a coating? Do you have a screed in the bathroom?
Are you referring to me? So far we don’t have anything yet, but it would probably be a screed and waterproofing with a coating; until this thread, I had never heard of using a membrane.
