ᐅ Vinyl flooring with concrete look without seams (high durability rating, recommended?)
Created on: 5 Nov 2023 03:38
SarahMüllerHello,
I have been searching for a while but haven't found much.
I am looking for a vinyl floor with a concrete look in a light gray shade without joints.
It should have a high to very high wear rating and be seamless with a soft appearance, so not too busy.
Does something like this even exist? The options are already quite limited without joints.
Hello Sarah.
You wrote "Vinyl flooring with a concrete look in light gray without joints"
Vinyl floors, meaning PVC flooring, are only available either in tile format or as roll material.
What you mean exactly by "joints" is not clear from your inquiry.
With tile formats, you will always have joints along the edges, which according to technical standards do not necessarily have to be (thermally) sealed, but for several reasons not listed here, they should be sealed.
With roll material, you have seam edges, which in a broader sense can also be referred to as "joints."
So, what exactly do you mean?
The "concrete look" you mentioned should not be a problem with PVC coverings, as there are countless designs available.
Regards, KlaRa
Regards, KlaRa
