Z
zaubermaus847 Jul 2021 10:51Hello,
we are considering having vinyl or luxury vinyl flooring installed. Approximately how much did you pay for 145 sq meters (1560 sq ft)? We would like to have a glued-down floor. Is it cheaper than installing tiles or hardwood flooring?
The material is more expensive than the cheapest tiles. It is about the same price or slightly less expensive than the most affordable hardwood flooring but can also be more expensive than high-quality tiles or hardwood.
So, in the end, the cost differences are minimal.
Installation is likely to be about as complex as gluing down hardwood flooring (possibly easier, as some types can be cut with a utility knife).
Tiling is the most labor-intensive.
Compared to laminate flooring, I find this material too expensive since it is fundamentally quite similar. So if you are very price-conscious and don’t mind plastic in your living area, I would recommend laminate instead.
Myrna_Loy7 Jul 2021 11:15I wouldn’t glue down cheap materials. The lifespan of laminate or luxury vinyl flooring is about 15 years, and neither can be sanded or refinished. In high-traffic areas, it can be even shorter, depending on quality and maintenance. Removing glued-down flooring is really a hassle.
nordanney7 Jul 2021 11:26zaubermaus84 schrieb:
We are thinking about having vinyl or luxury vinyl flooring installed. How much did you roughly pay for 145 sqm (1560 sq ft)? We would like a glued-down floor.And why do you want to have a synthetic floor installed throughout the whole house, considering the performance offered? You might as well just lay Aldi shopping bags on the floor 😉 .C
Chris25118 Jul 2021 09:19Roughly estimated 10-15k.
- Primer
- Subfloor
- Vinyl flooring
- Baseboards / skirting boards
- Clips
- Corner and transition profiles
- Transition strips
- Finishing strips
It’s best to visit local suppliers and request quotes. Don’t forget the plans.
- Primer
- Subfloor
- Vinyl flooring
- Clips
- Transition strips
- Finishing strips
