we are wondering on which side of the door is the best option to install a video doorbell.
I have attached our floor plan of the entrance area.
There is the option to mount it either on the right side of the front door on the protrusion or on the left side next to the door on the wall.
Which option would you say is better?
A simple Ring, Nest, or Eufy doorbell is planned.
@Araknis Thank you for agreeing that you definitely have to think carefully about where to place everything.
Once the cables are installed, you can no longer change that.
Currently, our favorite option is:
Green for mailbox and video doorbell
Red for ekey
@Araknis What would your recommendation have been?
Red for ekey
Araknis schrieb:
Well, you really have to think about it. For me, @netuser already gave a clear and understandable answer in the first post and also followed up. Yesterday, I was surprised that the topic actually reached over 9 pages.
On the subject, my answer aligns with @netuser’s. The (video) doorbell should be placed on the side where the door handle is. Then positioned frontally so it can capture a direct view and be able to see clearly.
Araknis schrieb:
You just have to think about where and how someone would approach the door to ring the bell if they were a guest. Then you can decide where the camera will see them and where it won’t. This is different before, during, and after the coronavirus pandemic anyway. And as a stranger, you behave differently at the door than a friend does. The depth of the entrance threshold and the space between the door and the street also matter. Plus, from which direction you come—left, right, or straight on.
Our strangers also stand differently than friends.
@Tolentino We cannot influence the pattern in which the bricks are laid. From the outside, all the houses must look the same.
The only things that can be customized are the lamps, mailbox, doorbell, and plants in front of the house.
The mailbox must definitely be green.
We are still unsure about the doorbell, deciding between blue and green.
For the ekey system, we are deciding between red and blue.
AlexKayn schrieb:
@Musketier
I have already looked for a mailbox and video doorbell (Doorbird) combination, but they are only available with about 45cm (18 inches) width, which unfortunately does not fit on the wall to the left of the door, between the front door and the WC window.z-e-d offers a version with the B2V Doorbird, an integrated Doorbird and mailbox unit recessed into the wall, with only 35cm (14 inches) width.
