ᐅ Video doorbell—on which wall should it be installed?
Created on: 31 Aug 2022 13:14
AlexKayn
we are wondering on which side of the door is the best option to install a video doorbell.
I have attached our floor plan of the entrance area.
There is the option to mount it either on the right side of the front door on the protrusion or on the left side next to the door on the wall.
Which option would you say is better?
A simple Ring, Nest, or Eufy doorbell is planned.
Grundriss eines Gebäudeteils mit Wänden, Türen, Fenstern und Maßangaben.
AlexKayn
2 Sep 2022 14:33
@Musketier
If the doorbell is installed at the green mark, shouldn’t it still be able to see someone standing right in front of the door? Most doorbells have a very wide field of view.
Doorbird, Ring, and Eufy definitely offer an angled mount that can be installed in emergency cases.
Right now, we are leaning towards placing the doorbell at the green mark and the mailbox there as well.
Is it okay to install the mailbox at about 1.20–1.25m (4–4.1 feet) from the ground to the top edge, or is that too low?
Our electrician doesn’t want to lay empty conduits outside. His argument is: How am I supposed to seal them properly?
K a t j a2 Sep 2022 14:35
Maybe just mount the camera above the door?
I can’t really understand the depth of the problem. Do people actually use such a high-security system? I’d have to be living in Mexico before I’d install something like that. Instead, I can just see who’s at the door directly if it has a window anyway. But okay – to each their own toy. 😉
AlexKayn
2 Sep 2022 15:10
The idea is to be able to see who is at the door when you are away or in the upper floor, attic, or basement. This way, you don’t have to rush to the door to prevent the delivery person from leaving again.
Musketier2 Sep 2022 15:24
AlexKayn schrieb:
So you don’t have to rush to the door to stop the delivery person from running away again
Are you really that fast at unlocking your phone before the delivery person leaves? 😉
K a t j a schrieb:
I can’t really grasp the depth of the problem. Do people actually use this high-security system?
I can gladly lend you my mother-in-law sometime. Then you’ll know what you need it for. :p
Musketier2 Sep 2022 15:39
To bring some more interest to the thread: What kind of fingerprint scanner do you use?
Vertical (e.g., integra) or angled (e.g., FS UP E or ekey home)?
For a vertical scanner, 1.20m (4 feet) seems too low to me. I can’t bend my finger that far.
fab101
2 Sep 2022 15:48
AlexKayn schrieb:
May I ask at what height you installed the Eufy?
Our doorbell is installed starting at 110 cm (43 inches) from the ground. As mentioned, it is battery-powered. We simply mounted it above the (useless) power connection of the old doorbell.
I can only recommend testing the final position with a video doorbell – there are reportedly delivery services that may accept mistakenly ordered doorbells as returns. It is also important to test the distances for the camera’s field of view.
