ᐅ Ventilation System by Pluggit – Issues with Excessively Dry Air
Created on: 18 Dec 2015 11:01
KuA13
Who else here has a ventilation system and experiences air that is too dry? Unfortunately, we are all currently dealing with bronchitis and are concerned that it might be related to our ventilation system. We would be very grateful for any experiences or advice on what we could do!
fcbchat
25 Nov 2017 11:42
We have a Pluggit Avent P300 ventilation system, now 10 years old. In winter, the indoor humidity level is around 20%. Despite daily showers, drying laundry indoors, and using small humidifiers in the living room and bedroom, we never managed to get it above 30% and experienced stuffy noses all winter. Since this year, we have been using the Pluggit AeroFresh Plus and no longer have any issues. The humidity level is exactly as we set it. We are very satisfied. This also means we don’t have to raise the heating (underfloor heating with an air source heat pump) as high.
blaupuma5 Jan 2018 00:32
Hello, we are supposed to get a Nilan Comfort 300.
Without humidity recovery!
Nilan does not offer that option.
I spoke with them today.
Nilan says that humidity recovery is not necessary. In winter, you can simply reduce the system’s output as needed. This way, the air is not completely exchanged, and the humidity increases!
Turning off the system is also possible!
Mycraft5 Jan 2018 07:31
That would be like going to a car manufacturer and saying, "The fuel consumption figures don’t match," and the manufacturer responding, "Then you just have to drive more slowly."
With the same logic, they could have said, "You could also just leave out the system entirely, then you wouldn’t have any problems with air that’s too dry."
You can only shake your head at that.
tomtom795 Jan 2018 08:28
blaupuma schrieb:
Nilan says that a heat recovery system is not necessary. In winter, you can simply reduce the system’s output if needed. This way, not all the air is exchanged, and the humidity level increases!
Turning the system off is also possible!
And in summer, you need to switch it off to prevent too much heat from entering.
Lumpi_LE
5 Jan 2018 09:55
... the explanation is really unbelievable.
My heating uses too much energy in winter – well, then just turn it off. Problem solved.
Bieber0815
5 Jan 2018 10:08
You are “supposed to”... How much freedom do you have in your decision? Do you own the land? What contracts have you already signed?
There are also other systems and different installers, planners, etc.
