ᐅ Prefabricated house ventilation duct punctured. What potential damages can occur?
Created on: 26 Oct 2021 09:11
HäusigefundenH
Häusigefunden26 Oct 2021 09:11Hello, I have purchased a prefabricated house (timber frame construction). While working inside the house, I accidentally drilled a hole for an input socket and nicked the ventilation duct. There are a few small holes in it.
I initially sealed the holes in the duct with silicone. Since it is located inside a partition wall, I do not expect significant temperature fluctuations. Therefore, I assume that no condensation will form inside. However, I am not an expert and would like to hear your opinions on this.
Martin
Martin
Baubaubau26 Oct 2021 19:42Is it an exhaust or a supply air duct? For exhaust, it’s usually not a problem; I would just seal it with aluminum tape and that should be fine. For supply air, depending on how much the supply air valves attached to the duct are throttled, the pressure could cause it to become leaky over time.
Baubaubau27 Oct 2021 12:55@konibar You are definitely right about that! But with an exhaust pipe, a minimal leak wouldn’t bother me, which is why I’m asking.
Häusigefunden28 Oct 2021 08:38Hello, how can I tell if this is an exhaust or supply air duct? I’m thinking of removing the silicone again and applying SikaFlex adhesive; that should give me long-lasting peace of mind. :-)
Baubaubau28 Oct 2021 10:24Which outlet does the pipe lead to? Can you identify it? Then check there…
