Next week, we will continue with the electrical work. A KNX wiring system would be ideal, but unfortunately, it’s no longer within the budget. So, for some added convenience, I have come up with the following combinations for now. “Only” the shutter switches and room temperature controllers for the time being. I’ll share my idea for the light switches later.
Could someone please take a look and see if I’ve missed anything important? I’m not concerned about the “small parts” right now.
Shutter Switches
Room Temperature Controllers
I am still a bit unsure here. What exactly do I need to implement the following controller?
I’m stuck here at the moment. We want to be able to control the light switches remotely as well (on/off). The light switches should also have a dimmer function. So far, I have found the following, which should point in the right direction:
Thank you all!
Stefan
Shutter Switches
- Busch-Jaeger 6411U/S-101 Busch Shutter Control II Insert (Item number: 6410-0-0379)
- Busch-Jaeger 6455 Comfort Timer Control Panel 6455-101 (Item number: 6410-0-0397)
- Busch-Jaeger 6435-214 Central Cover Plate (Item number: 6430-0-0402)
- Busch-Jaeger 1098 UF-101 Electronic Room Temperature Controller Insert (Item number: 1032-0-0509). This is the version with an external remote sensor. How do I know if this is necessary?
- Busch-Jaeger 6164/10-101 Thermoelectric Actuator with Function Indicator 6164/10-101 (Item number: 6164/10-101)
- IR Control Panel with Label, Illuminated (Item number: 6066-24-102)
Thank you all!
Stefan
Sebastian79 schrieb:
The rough-in installation is already done, right?
What do you want to control and how with the blinds now?
I’ll refrain from commenting on the heating control Same here
How many roller shutters are there? And as Sébastien already asked, which comfort functions are desired?
Except for the cables coming out of the blinds/shutters, no wiring has been installed yet. A few openings have been made, but as mentioned, there are no cables installed so far.
20 roller shutters. Desired features: up/down control with a light sensor (manual/automatic), different switching times during the day and for weekdays versus weekends. Random mode (vacation). That’s basically it… A central switch per floor would be preferable, but depending on the functions of the individual switches, it is not necessarily required.
Sebastian793 Jan 2016 18:13And that price for this? As I said, look at what I paid – it can be done even cheaper.
Sebastian793 Jan 2016 18:26Yes, exactly – but then you should choose everything from GIRA. It also needs to appeal to you visually...
