ᐅ Vapor barrier or vapor retarder for insulation of top floor ceiling: to use or not?
Created on: 13 Jan 2025 14:07
gonzinho
gonzinho
13 Jan 2025 14:07
I want to insulate the ceiling of the top floor. I have already read some posts, but my question unfortunately hasn’t been answered. At least, I haven’t found anything about it.
First of all, the situation: It’s a house built around 1870 in the Vordereifel region. The walls are typical for the area, made of lava rubble stone, filled with a clay/straw mixture, but there are also some slate stones here and there. The ceilings are wooden beam ceilings filled with a clay/straw mixture. The ceiling of the top floor, however, has an additional very hard layer. It looks like concrete but is some kind of screed(?). Maybe the pictures provide a clue. The roof structure is not insulated and should not be insulated. The room is only used as storage. Therefore, I wanted to install insulation on the floor, preferably 140mm (5.5 inches) polystyrene boards, and then a walkable layer on top. OSB boards, if that is possible…
To even out the unevenness of the floor, I planned to install battens and fill the gaps with polystyrene beads or something similar.
My actual question is: Should I place a vapor retarder or even a vapor barrier on top of the screed?
Case a) There is diffusion through the screed layer. Although I find it hard to imagine how warm, moist air could pass through this layer, it apparently has, otherwise there would already be a moisture problem in the ceiling(?). In this case, a vapor barrier would be counterproductive, as it would prevent this diffusion and cause exactly this moisture problem. Or is this assumption wrong? If it is correct, I would only need to ensure that the moist/warm air can also pass through the insulation into the attic space. So definitely no OSB boards on top, but a “breathable” walkable surface (tongue-and-groove boards?). And would polystyrene still be suitable? There are conflicting statements on this.
Case b) There is no diffusion through the screed layer, and my house just never had a moisture problem in the ceiling. Then a vapour-open insulation would not be necessary; I could use polystyrene plus OSB boards.
How can I determine which case applies to my situation? Are there any measurement methods for something like this?
Markus
P.S.: Picture 1 shows the attic, picture 2 shows the screed construction (at this point, a no longer used ventilation pipe comes out of the floor), picture 3 is a close-up of a small piece of screed
Dachboden mit Holzbalken, kleinem Fenster, schwarzem Schrank, Rohren und Bauholz.
Freigelegter Bodenbereich mit Holzplanke, lose Erde, oranger Dämmstoff und silbernem flexiblem Rohr.
Grauer Betonbrocken liegt auf dem Polsterarm eines dunklen Sofas; unscharfer Hintergrund.
