ᐅ Vapor barrier for the first floor when the ground floor is a garage?
Created on: 25 Jan 2026 23:51
Schwabe67S
Schwabe6725 Jan 2026 23:51Hello,
Currently, my living area consists only of the concrete ceiling of the garage. I plan to install laminate flooring there, and now the question is whether to use a vapor barrier or not.
Schwabe67
Schwabe67
Schwabe67 schrieb:
My living space currently consists only of the concrete ceiling of the garage, and laminate flooring is planned to be installed here. Now the question is whether to use a vapor barrier or not? Am I correct in assuming that the motivation behind your question is that this first floor is the lowest level of the thermal envelope, and the garage below, being an unheated garage, is effectively in a different climate zone, so you expect condensation at the interface between the garage ceiling and the living room floor?
It would make sense to consider the insulation and thermal protection of the garage ceiling structure as a whole, meaning its entire build-up (not just the question of whether or not to add a vapor barrier directly under the laminate).
With that in mind, here is my standard suggestion for newcomers: discuss everything in context and not as a mere “textbook exercise.” Be aware that there are only a few mind readers here; therefore, please share the complete overall design. Are we talking about a new build?
Schwabe6726 Jan 2026 01:20Thank you for the detailed response. In this case, I am completely unaware of the role a boundary layer or thermal envelope plays here.
This is a rental apartment; the previous tenant stayed for nine years, but I cannot provide any more information about the building’s age. The construction of the ceiling is also unknown.
The garage door seems to allow some airflow, which carries away condensation.
While researching, I came across this information, which recommends using a vapor retarder because of a mineral-based floor.
https://www.dasheimwerkerforum.de/threads/neu-verlegter-laminat-hat-sich-ausgedehnt.12744/
External links are not allowed here.
The breeze doesn’t just remove condensation, it also brings moisture in – but on the underside of the garage ceiling, while the vapor you want to stop would condense on the upper side of the ceiling (your floor). Whether the floor-ceiling assembly consists only of concrete and screed (i.e., a two-layer monolithic structure) or includes other layers of different materials is very important for answering your technical question. Maybe @KlaRa can provide some insight on this. If you are a tenant, you should coordinate your plans with the landlord, and if you own a unit within a condominium association, you should discuss it with the co-owners’ meeting.
An interface refers, for example, to a surface or a contact point between two layers that differ especially in their physical properties. The thermal envelope is the enclosure of a building component or parts of it—for instance, the package of residential floors between a cold basement and an unheated attic space, where insulation layers are installed at the basement ceiling and on the attic floor.
If you have no understanding of all this and it’s completely unfamiliar to you, you should avoid installing laminate flooring yourself, at least for warranty reasons. If you hire a professional tradesperson, they should be able to answer these questions independently—that is part of their professional qualification. Anyone who interprets “tradesperson” as “someone who doesn’t need to think” should definitely not operate commercially in this field. And tenants should avoid damaging the rental property, which can easily happen through poor workmanship.
Schwabe67 schrieb:
In this case, I am completely unaware of the role that an interface or a thermal envelope plays.
It’s a rental apartment; the last tenant stayed there for nine years, but I can’t say more about its age. The ceiling structure is also unknown.
The garage door rather looks like it lets a breeze in, which carries away condensation.
