ᐅ The Vaillant VCW 196EC is experiencing intermittent operation issues.
Created on: 28 Nov 2025 10:46
Curiosius
Good morning,
a Vaillant Vcw 196EC heating system frequently stops working intermittently. It runs normally, and then, without any changes to the settings on the unit or the radiator thermostat, it displays the error E12. Sometimes also F40 or F23. Pressing reset stops the issue for hours. A new expansion tank and several other parts have been continuously replaced. It still needs to last a while... There is enough water in the system. What could this be?
Curiosius
Curiosius
Curiosius29 Nov 2025 11:01You mean to slightly loosen the mentioned valve at the bottom of a heating circuit first?
Curiosius29 Nov 2025 14:40Of course, carefully. I have special training in the renovation sector, no matter what. Always with thoughtfulness and calm.
What’s still not quite clear to me is whether you mean the side of the thermostat or the opposite side. Naturally, below in each case?
Yes, the return valve is located below, opposite the thermostat. It is usually just a small Allen key screw, so it’s easy to overlook. Give the valve insert only a very slight turn, no more. If a radiator remains noticeably colder at the return side, you probably have a flow rate loss exactly there, which is disrupting your central heating system.
Curiosius1 Dec 2025 23:05Many thanks!
I noticed that for older models, there is a special key... Is it necessary because of the precise fit?
