muammer_je3 May 2022 18:14Hello everyone,
I am considering using an IKEA Kallax shelf unit as a workbench. I am particularly interested in how stable this solution really is, especially when performing heavier tasks or applying point pressure, such as hammering or screwing. Can the Kallax withstand these stresses due to its modular design and relatively thin side panels, or is it more of a makeshift solution that I should rather avoid? Are there any experiences with reinforcements or modifications that improve its stability?
I look forward to your assessments and tips.
edisondan3 May 2022 19:15The Kallax shelving unit is based on a lightweight particleboard construction with a veneer layer. This material choice is intended for furniture primarily used for storage, not for workbench use involving localized stress such as hammering.
To improve stability, I recommend:
1. Securely placing and fixing a solid worktop (e.g., plywood or beech wood).
2. Mounting the Kallax unit to the wall to prevent tipping.
3. Installing side brackets or metal profiles for reinforcement.
Without such modifications, the stability remains relatively low.
You might also want to consider whether furniture with a full back panel or a solid wood version would be more suitable.
I also use my Kallax as a workbench in my hobby area. At first, I was skeptical, but with a few modifications, it works well. It is important that the shelving unit stands on a level floor and does not wobble. Instead of the original Kallax board, I used a 28mm (1.1 inch) thick multiplex plywood panel as the work surface – this makes a significant difference in stability and feel.
Additionally, I reinforced the back panel with a thin OSB board to reduce lateral movement. The shelving unit is screwed to the wall, which ensures a secure and stable setup. If you do hammering work, you should still use an extra, preferably solid, base underneath, as the original particleboard could otherwise be damaged.
Conclusion: The Kallax can definitely be used as a workbench if stability is improved through reinforcements and appropriate precautions are taken.
muammer_je4 May 2022 11:43edisondan schrieb:
To increase stability, I recommend a solid worktop... side brackets... wall mounting.Thanks, these tips are exactly what I was looking for. What do you think about the idea of reinforcing the shelf compartments with fixed shelves made of multiplex plywood? Would they hold together better than the original shelves?
And one more question: How about the load capacity? I might have some devices weighing a few kilograms (a few pounds) on the workbench, but how does it handle point loads, like screws driven in with a lot of force?
The original shelves of the Kallax are made of 12 mm (0.5 inch) chipboard, which is often not sufficient for heavy loads. Replacing them with 18-20 mm (0.7-0.8 inch) plywood panels significantly improves load-bearing capacity, as plywood consists of layered veneers that better withstand point loads.
For point loads (e.g., heavy screwing or hammering), the following approach is recommended:
- Worktop made of solid wood, 28 mm (1.1 inch) or thicker
- Optionally, install reinforcements in the lower section to prevent sagging
- Shelving compartments can be further stiffened with plywood panels; however, this does not replace the need for wall mounting
Additional note: The Kallax is not originally designed for use as a workbench, so these measures are essential if stability is important.
