ᐅ Using a BILLY Shelf in Damp Areas – What Should Be Considered?
Created on: 21 Sep 2022 09:37
Liserdem
Liserdem
21 Sep 2022 09:37
Hello everyone, I am currently planning to use a BILLY shelf from IKEA in a damp room—specifically in our guest shower bathroom, which only has limited ventilation and occasionally becomes humid. My question is: What should I definitely consider when using a BILLY shelf in such a moist environment? I would like to know if the shelf material (particleboard with a foil coating) is suitable for increased humidity, or if I should take special protective measures, such as treating it with water-repellent products or applying an additional sealant. I am also interested in whether the manufacturer explicitly advises against using it in damp rooms and what your experiences are regarding the durability of these shelves under such conditions. I look forward to your assessments and tips on how to safely and securely use a BILLY shelf in an environment with occasional moisture.
KAUDRA62
21 Sep 2022 10:03
Hi Liserdem 🙂 The BILLY shelves are not really designed for damp rooms, as they are made of particleboard with a laminate surface – which is sensitive to moisture. However, in a bathroom with only mild humidity and good ventilation, you can still use the shelves with a few precautions. The most important thing is not to place the shelf directly against walls that are constantly wet. A few centimeters (inches) of space can already create much better air circulation.
I also think applying a thin layer of clear varnish or a special wood sealant is a good idea. This helps protect the surface somewhat against moisture. And be sure to check from time to time if any corners are swelling or if the laminate is bubbling – prevention is key here. Don’t worry, with some care, the BILLY shelf can handle humidity quite well. 🙂
nonpra
21 Sep 2022 10:57
BILLY shelves are not designed for damp rooms. If you still want to use them there, make sure to keep a gap between the shelf and the wall and treat it with moisture protection. Otherwise, the material will swell.
Surela
21 Sep 2022 14:12
Hello Liserdem,
to provide a well-founded answer regarding the BILLY shelf in damp rooms, it is important to consider the material composition and the specific conditions of your damp space. The BILLY shelf is mainly made of particleboard covered with a melamine foil. While this foil offers some resistance to moisture, it is not waterproof. Therefore, if the shelf is exposed to consistently or frequently high humidity and occasional wetness, moisture can penetrate through small gaps, causing damage such as swelling, warping, or delamination.
However, there are some measures you can take to increase its durability:
1. Avoid direct contact with the floor: Place the shelf on adjustable feet or small spacers to prevent standing moisture from being absorbed from below.
2. Protect the back panel: In environments with elevated humidity, sealing the back panel with water-repellent paint or foil can help.
3. Seal the surface: Applying a thin layer of transparent wood or furniture varnish with water-repellent properties to all visible edges and surfaces is beneficial.
4. Ensure ventilation: Active ventilation or regular airing out reduces humidity and helps prevent mold growth.
According to the manufacturer’s information, IKEA recommends not using the BILLY shelf in rooms with very high humidity, such as wellness areas with a lot of steam. However, for a guest bathroom with a shower that is only occasionally damp and well ventilated, it may be possible to achieve satisfactory results with the right precautions.
I would also like to know: How often does moisture occur in your guest bathroom, and what exactly are the ventilation options? This information can help better assess the risks.
Liserdem
21 Sep 2022 16:42
Surela schrieb:
I would like to know: How often does moisture occur in your guest bathroom and what exactly is the ventilation setup?
That’s a good question! The guest shower bathroom is used only occasionally by visitors, at most 2-3 times per week, and after each shower the door is usually left open for 1-2 hours to allow the moisture to escape. There is no mechanical ventilation, only a small window that can be opened. During these short periods, the humidity rises to around 70-80% and drops back relatively quickly to normal levels below 60% after airing out.
I want to avoid the shelf gradually warping or becoming damaged by moisture over the years because I really like it both visually and functionally. Apart from not wanting to make any major renovations, a waterproof shelf is therefore not really an option. So I am primarily interested in the most effective way to protect the existing material.
Hector
22 Sep 2022 08:54
That is technically correct, but I think such statements are often too absolute. Depending on the specific use, many products can be used even outside their original specifications—if you understand the conditions and act accordingly.
Surela schrieb:
There are measures like sealing, clearance from the floor, and back panel protection.
These are important points. I want to argue that the focus should not only be on short-term protection. It is much more important to precisely control ambient humidity and ensure good ventilation. It should also be understood that once moisture accumulates permanently or in large amounts, neither filling nor painting will provide long-term protection. The material will be damaged within a few months.
Another often overlooked question is how quickly and carefully such shelves can be replaced or repaired when signs of moisture appear. Perhaps a higher willingness to perform maintenance is a better strategy than particularly elaborate prevention?
