ᐅ Using BILLY Shelving in Damp Areas – What Precautions Are Needed?
Created on: 24 Oct 2023 20:13
penon30
penon30
24 Oct 2023 20:13
Hello community,
I am planning to use a BILLY bookshelf from IKEA in a damp area, specifically in my bathroom, which is only occasionally humid (e.g., during or after showering). I am aware that BILLY bookshelves are made of veneered particleboard, which is generally not designed for permanent moisture exposure.
I am particularly interested in which precautions I should take to ensure the shelf lasts as long as possible without swelling or developing mold. For example, is sealing it with paint or oil sufficient? Or would it be better to place the shelf in a specific location to avoid water splashes?
Are there any experiences with alternative moisture-resistant shelves from the furniture market that are similarly affordable and flexible?
Thank you very much for your tips and advice!
Palenar
24 Oct 2023 21:49
Hello penon30,
Your project is definitely feasible, but as you have correctly suspected, the BILLY shelf is not specifically designed for damp environments. The typical MDF or chipboard construction is sensitive to moisture because the material absorbs water, which causes swelling and warping.
I recommend a multi-step approach:
1. Priming and sealing: First, use a high-quality primer that is specifically suitable for wood and wood-based materials. Then, seal the shelf all around with a waterproof clear varnish, applying at least two to three coats with sanding in between. Pay special attention to edges and drilled holes, as these areas are particularly vulnerable.
2. Placement: Position the shelf preferably at a wall spot that is not directly exposed to splash water. Ideally, choose an area with good air circulation so moisture can escape quickly.
3. Air circulation: Avoid placing the shelf directly against the wall to prevent moisture that forms on the wall from directly affecting it. Small supports or spacers under the feet can help.
4. Regular inspection: Regularly check the shelf for damage or mold and treat it as necessary.
Alternatively, furniture made of plastic or metal is significantly more moisture-resistant. A shelf designed for damp rooms, made of aluminum or painted steel, can be a good alternative, especially in wet zones. These are usually more durable in moist conditions but often cost significantly more than the BILLY.
What exactly is your intended use and installation location? Is it a main wet area or only a temporarily damp zone? This is crucial for determining the extent of the necessary measures.
Davidleo
25 Oct 2023 07:36
Hey penon30!
It’s really exciting that you want to use the BILLY shelf in your bathroom! 🙂 I think it’s great how you’re already looking for the best tips so specifically!
I once had a shelf like that in my bathroom too – but I made sure not to place it right next to the shower. At home, I also stuck a few self-adhesive moisture protection pads under the feet, which really helped.
And the tip about clear varnish is spot on! I treated the entire surface with marine varnish – it keeps the shelf looking fresh for a long time and provides excellent protection. I also think it’s a good idea to use a small temperature and humidity sensor so you can always monitor how “hot” it gets in that corner :-)
Regarding alternatives: I’ve also seen moisture-resistant furniture made of plastic at a hardware store, which looked very modern. But honestly – for the price, the BILLY is really a classic!
Keep at it, you’ll manage!
KIN42
26 Oct 2023 12:57
Palenar schrieb:
Typical MDF or particleboard constructions are sensitive to moisture because the material absorbs water
I completely agree. Additionally, I would like to mention that using a wood preservative specifically designed for damp environments is advisable, especially if you do not want to fully seal the surface.
penon30 schrieb:
Is sealing with varnish or oil, for example, sufficient?
Varnish has the advantage of creating a hard, water-resistant surface. Oil penetrates the wood but usually provides only limited protection against prolonged moisture exposure. If your bathroom tends to stay humid for extended periods, varnish is the better choice.
Ventilation is also crucial: without regular air circulation, moisture levels will rise, which over time can damage almost any wooden furniture.
If you want to mount the shelf on a wall, be sure to check that the wall can dry out and is not damp—no protective treatment will help if the furniture is in constant contact with wet walls.
In summary:
- Seal with clear varnish, preferably in multiple layers
- Pay special attention to protecting edges and the back side
- Install the shelf in a well-ventilated area
- Avoid direct contact with water at all costs
For consistently high humidity, I recommend an alternative made of plastic or metal.
