ᐅ Using Geothermal Energy Without Radiant Floor Heating
Created on: 12 Aug 2012 04:43
DoorPP-1
12 Aug 2012 04:43
Hello dear forum!
I would like to use geothermal energy as a source, but I am not a big fan of underfloor heating. Is it necessary to install underfloor heating to use geothermal energy, or is it also possible with regular radiators?
MODERATOR
15 Aug 2012 19:42
The idea behind using heat pumps is to combine the lowest possible supply temperature (26°C (79°F) is usually sufficient) with a large heat exchanger surface area. This way, a well-insulated house can still be heated effectively even under adverse climatic conditions for the heat pump.
Large surface heat exchangers can also be wall heating panels; they work the same way as underfloor heating but are installed within the walls.
Standard radiators require a relatively high supply temperature to heat a house; high temperature means a small heat exchanger surface area, while low temperature requires a larger heat exchanger surface area.
WPC Rubigen-1
18 Nov 2014 12:09
You can easily use a geothermal heat pump with radiators. The efficiency is somewhat lower compared to a system with underfloor heating, but still good. What matters is that the system is properly designed and hydraulically balanced. Consult a heat pump specialist to ensure everything fits together correctly.
Louis-1
19 Nov 2014 07:19
WPC Rubigen schrieb:
The key is that the system is properly designed and hydraulically integrated correctly.
That is true, and I fully agree with the previous poster. This cannot be done alone; a professional is needed here, and they usually handle it well.
Mattia-1
30 Nov 2014 17:39
That is correct, this also works with radiators. The heating system must function well, and for the upcoming winter period, the supply temperature should be limited to a maximum of 40-45°C (104-113°F). At the same time, disable the night setback and turn all radiators fully on. Once the house is warm, then considering a heat pump is possible. It is important to obtain current quotes.
Marcel-1
31 Jan 2015 15:50
Yes, this is possible without underfloor heating, but special radiators designed for heat pump operation must be installed. Although this is not ideal, it does work. You should also consult a heating engineer, who can calculate the heating load.
