Hello
I have three boys! We have limited space and urgently need a urinal!!
If we didn’t need a built-up wall, it would be doable!
So the question is about a space-saving urinal with water supply and drainage from below... then the urinal could be mounted on the wall and the pipes could run inside a built-up wall beneath the urinal.
Does such a product exist? Manufacturer/name?
Or do you have any experience with this kind of setup??
Thank you very much!!
nordanney22 Sep 2019 12:07Trude80 schrieb:
I have three boys! We have limited space, and I urgently need a urinal!!What do three boys have to do with limited space and needing a urinal? Remove the urinal, and there’s more space. Just sit down as it should be, and everything works fine.I have three girls, and a regular toilet works perfectly.
Fummelbrett!22 Sep 2019 12:59Is it not possible to install the pipes within the wall?
nordanney22 Sep 2019 13:30Bookstar schrieb:
A urinal is the most important feature in a new build,However, the majority of Germans see it differently Bookstar schrieb:
For a man, sitting down is not only inconvenient but also very unhealthy!Ask your urologist. They will tell you otherwise, especially as you get older—sitting down is definitely healthier than standing.
