I have visited several developer-built houses and noticed that they construct the upper floor without a screed layer. Friends and acquaintances also sometimes do not have screed on their upper floors. The insulation for, for example, laminate flooring is placed directly on the concrete, with the laminate installed on top.
How should this be approached, considering that developers build the upper floor without screed? Should one be cautious, or is this common practice nowadays?
Hi,
the houses do not have underfloor heating, and the electrical wiring and related installations are embedded within the concrete. This seems to be an increasingly common practice to save construction costs. Although I cannot imagine that the screed itself is particularly expensive. The concrete is also prepared to be level enough to allow for the installation of impact sound insulation and other floor coverings.
Sebastian795 Jun 2016 14:45Payday schrieb:
How do you install electrical wiring, underfloor heating, and similar systems? Do you mill them into the concrete ceiling?Regarding the electrical cables: On the upper floor, I have (almost) no cables lying on the floor – and I haven’t milled any chases across the floor for them.
Sebastian79 schrieb:
Regarding the electrical cables: I have (almost) no wiring on the floor in the upper floor – and therefore no cross chases milled. And then where are the cables laid? You probably have wireless power or something like that^^
