ᐅ Until when is it possible to install outdoor tiles? (Regarding temperature)
Created on: 17 Nov 2008 10:26
Hansi-1
17 Nov 2008 10:26
today I have a question and I hope someone is available to answer it. We want to lay tiles on the terrace, but is that still possible? It gets very cold at night, and I’m worried that the adhesive might not set properly. Or is this not an issue with outdoor tiles?
Elefant-1
18 Nov 2008 07:49
Hi,
at this late time of year, I wouldn’t lay any tiles anymore because, as you have already noticed, it simply gets too cold at night. The adhesive can no longer cure properly, and due to the moisture in the cement, everything can crack again if it freezes. It’s better to wait until next year; then success is guaranteed.
O
oobravo-1
18 Nov 2008 09:44
Hi
I also believe it is already too cold to lay tiles outdoors, as the adhesive can no longer cure properly in cold conditions. It is best to wait until spring and start when the nights and days get warmer again.
Best regards, oobravo-1
Helmi-1
25 Nov 2008 12:22
How the temperature affects the adhesive is usually indicated on the packaging. If you follow the instructions, nothing should go wrong. However, if the temperature drops below freezing, I cannot imagine that it will work properly.
