ᐅ Uninsulated Roof Framework – How to Prevent Mold?
Created on: 16 Jan 2018 18:21
MiIng
MiIng
16 Jan 2018 18:21
While planning our single-family home, I have the following question:
How can mold be prevented in the attic?
I only want to use the attic as storage space with a pull-down ladder.
I don’t consider it necessary to insulate the attic itself. This means I would only insulate the ceiling of the upper floor.
I have often heard of mold problems occurring because construction moisture and other dampness get trapped and cannot escape.
Do you simply leave a section of the vapor barrier open, or are there more effective solutions?
bluminger16 Jan 2018 18:30
During construction, the opening for the retractable staircase must be closed off and sealed; this way, nothing should go wrong.
The vapor retarder is then also located at the collar beam level.
Joedreck
16 Jan 2018 18:32
Ensure proper ventilation in the attic and install tongue-and-groove boards instead of OSB panels for the flooring. This will prevent any issues.
ares8316 Jan 2018 19:35
For ventilation, plastic vents are installed at the overlaps of the roofing membranes. This allows good airflow. Our site manager said these were introduced precisely because of mold issues, and since then there have been no complaints. So far, everything is fine for us as well.
Lobster
18 Jan 2018 11:29
We have chosen triangular windows on both sides.
This allows us to ventilate completely across if any issues arise.
Additionally, natural daylight enters from both sides, increasing the usability of the space.
