ᐅ Underfloor heating without a thermostat – but how?
Created on: 18 Jan 2022 12:37
Bauenaberwie
I have often read here that the thermostats are more for decoration than actually used. We currently have underfloor heating as well, but our apartment building is over 20 years old, so I assume the insulation isn’t as effective as it is today. That means we adjust the heating a bit more frequently. However, I can imagine that once it’s properly set up, the heating just runs throughout the winter. But without the thermostats, how does the house determine the current temperature? And how is the underfloor heating controlled at all? Just by the control valves on the heating system? I hope someone can shed some light on this 🙂
Benutzer200
18 Jan 2022 13:41
Bauenaberwie schrieb:
So, if I can manage with 20 degrees in the bedroom, do I just reduce the flow there a bit?
It’s not quite that simple (trial and error helps), because if 1,000 liters per hour are pumped through the house and 150 liters go through the bedroom, the remaining 850 liters (just right for the desired room temperature in the other rooms) go to the rest of the house.
But if only 100 liters flow through the bedroom—meaning less heat input from the underfloor heating—then 900 liters go through the rest of the house, which may make those rooms somewhat warmer.
Bauenaberwie
18 Jan 2022 15:02
Benutzer200 schrieb:
This is not quite that simple (testing helps), because if 1,000 liters per hour are pumped through the house and 150 liters go through the bedroom, then 850 liters (exactly right for the desired room temperature in the other rooms) remain for the rest of the house.
But if there are only 100 liters in the bedroom—that means less heat input from the underfloor heating—then 900 liters flow through the rest of the house, which may cause it to be a bit warmer there.
That’s what I suspected. But I think it should be doable. Thank you very much.
fach1werk
18 Jan 2022 17:03
I occasionally visit someone who controls the heating solely by adjusting the flow rate. During the heating season, I now refuse to sleep there because I freeze my backside off, as the room is otherwise unused. The owner no longer likes to adjust the flow control because it requires very precise tuning, and afterwards, he can’t get it back to the way it was before. If you like that...
Mycraft18 Jan 2022 17:30
@fach1werk
This clearly indicates either incorrect operation or simply wrong settings. Or the person might just prefer it cold. I know people like that; they always need a maximum of 16°C (61°F) in the bedroom to feel comfortable. Other factors such as a generally too low heating curve and/or improper hydraulic system setup can also be the cause.
But that doesn’t affect the other controlled values, right?
As mentioned before, you should avoid making any further adjustments once the system has been balanced and the desired temperatures are reached. Because turning the controls later will throw everything off, not just the one room you are adjusting.
