ᐅ Underfloor Heating or Conventional Heating – Which Is More Cost-Effective?
Created on: 24 Jul 2012 04:45
-I heard on TV today that underfloor heating is supposedly more efficient than a conventional heating system because it only requires a flow temperature of 40°C (104°F) instead of 70°C (158°F). Is this really true? Can I ultimately heat my house more cheaply with underfloor heating?
MODERATOR25 Jul 2012 13:33Underfloor heating operates at a lower flow temperature, which is why it is often used in low-energy houses, as it requires less heating energy.
Whether heating your home is ultimately more cost-effective cannot be stated simply, because the flow temperature alone is not the only factor. Simply put, you need a certain amount of heating energy to raise a room to a specific temperature—regardless of the type of heating system warming the indoor air.
This should be calculated specifically for your house.
Christiana-15 Oct 2013 09:04In my opinion, a conventional heating system is better because underfloor heating can be difficult and costly to repair if it breaks down.
Richard-11 May 2014 10:23Underfloor heating is more environmentally friendly but has higher upfront costs compared to radiators. Maintenance costs are roughly the same for both. The advantage of underfloor heating is that there are no radiators, so more usable space is available.
Annegret-15 May 2014 07:25Hello,
It may be true that underfloor heating is more ecological than radiators. However, radiators warm up faster than underfloor heating. I also find the room climate better. Additionally, the regulation of underfloor heating takes too long for my taste.
Kind regards
Annegret
Kind regards
Annegret
Kurt1985-111 May 2014 07:08I see advantages in underfloor heating. Of course, a heat pump needs to be installed, which typically operates at a lower flow temperature than a traditional radiator.
