ᐅ Underfloor Heating – Flow Meters Show Zero Despite Flow
Created on: 17 Dec 2021 15:58
BananaJoe
maybe this question is too basic, but:
Do you need to do anything special with the flow meters (the small glass tubes with a scale up to about 3 liters per minute) to make them show the flow? In our distribution boxes, all except four of them do not show any flow, even though there is definitely water running through the heating circuits (warm supply and return).
Unfortunately, my builder (or rather the builder of my general contractor) is no help and a complete disaster, so I trust the collective intelligence here in the forum much more than any of his statements... 🙄
Thanks in advance!
Deliverer
17 Dec 2021 16:41
If the supply and return lines are swapped, they shouldn’t show any readings, right? Measure the temperatures of both pipes and see which one is warmer.
BananaJoe
17 Dec 2021 17:00
Deliverer schrieb:
If supply and return lines are swapped, they shouldn’t show any readings, right? Measure the temperatures of both pipes and see which one is warmer.
Correct! A Stiebel technician who visited two weeks ago noticed the supply and return lines were swapped, and this has since been fixed. So that shouldn’t be the issue, especially since four of the flow meters in the upstairs manifold are showing flow (while three others are not). In the downstairs manifold, none of the flow meters are showing any flow.
Deliverer
17 Dec 2021 17:14
Maybe the time during which it was connected incorrectly caused it to get "stuck"... Have you tried snapping your finger against it a little? Or turning on only individual zones at a time to increase the pressure on that zone, so the float can come loose?
OWLer17 Dec 2021 19:38
Close all other loops and only open the hanging ones, set the flow to maximum. I also once had a sticking float, and with sufficient pressure, it became operational again.
