ᐅ Connections of the underfloor heating system located in the wrong room
Created on: 31 Jan 2017 14:39
titoz
Our builder installed the pipes for the underfloor heating in the slab, placing them beneath the steel reinforcement. So, there is roughly 25–30 cm (10–12 inches) of concrete and steel above the pipes.
However, something went wrong, and the underfloor heating pipes are coming up through the floor in the dressing room instead of the utility room.
The architect suggested moving the wall in the dressing room forward a bit and routing the pipes inside the wall. But this would reduce the size of the dressing room by about 20 cm (8 inches).
Is it possible to break into the slab to reroute the pipes under the timber frame into the utility room?
What would you do in my situation?
Tito
11ant8 Feb 2017 01:34
wrobel schrieb:
Why would anyone confuse top and bottom there?
This is about concrete core activation. The setup is already correct as it is.
In my opinion, this is a neat solution, but it is probably more suitable for floor slabs between stories rather than for ground slabs.
[P.S. @ the moderators: am I doing something wrong if my quote boxes turn out extremely narrow?]
wrobel8 Feb 2017 09:48
Hello
No, this is also possible and correct for a slab foundation.
It is the case for us and various customer projects as well.
Try searching for "Schwedenplatte" or "Futura slab foundation."
Olli
