ᐅ Underfloor heating also in the utility room / technical room
Created on: 6 Sep 2017 13:06
Curly
Is it common to install underfloor heating in the utility room (ground floor), or is that usually avoided? In our utility room, there will be the gas boiler (with a 300-liter (79-gallon) hot water tank), the ventilation system, as well as the washing machine and dryer. Should underfloor heating be planned there as well?
How did you handle this?
Sabine
Bau-Schmidt
6 Sep 2017 15:43
Our two heating circuit manifolds are located in the storage rooms.
truce6 Sep 2017 15:47
So they cannot be used as buffer tanks.
Bau-Schmidt
6 Sep 2017 15:54
truce schrieb:
So it can’t be used as storage space
Correct. It’s not designed for that purpose. There is another room intended for that.
Alex85
6 Sep 2017 17:06
But actually, it's a waste. Now you have a nicely warm storage room. It would be smarter to have this in the bathroom.
ruppsn
6 Sep 2017 17:20
The utility room, as often mentioned, is indirectly heated by the heating circuit valve (HKV) usually installed there. The technical equipment also contributes to the heating.
In our case, the laundry room serves as the utility room, meaning it contains the washing machine, dryer, as well as the ironing station and work surfaces for folding clothes. Therefore, the time spent there is longer than in the technical room. We have installed some heating pipes running through this room on the way to other areas, so it is indirectly heated. This does not cost much and does not require a separate heating circuit.
Bau-Schmidt
6 Sep 2017 18:53
Alex85 schrieb:
But actually, that’s a waste. Now you have a nicely heated storage room. It would be smarter in the bathroom.
I don’t want the visually unattractive distribution boxes to be in plain sight.
