ᐅ Underfloor heating with an air-to-water heat pump. House gets too warm when the sun is shining.
Created on: 4 Dec 2019 14:18
chewbacca123
I have a general question.
We moved into our new build four months ago. The living area on the ground floor has three large floor-to-ceiling windows facing south. We have underfloor heating and an air-to-water heat pump.
It provides a really comfortable temperature inside the house, but we have a problem – whenever the sun is shining in winter, even if it’s -2°C (28°F) outside, the temperature suddenly rises to 24°C (75°F) in the living room. It gets uncomfortably warm in here, and the underfloor heating can’t be turned down quickly.
Should we assume that the large floor-to-ceiling windows are responsible for the heat gain? A photo of the south-facing side of the house is attached.
What would you do – always lower all the blinds as soon as sunlight is forecast? That seems quite annoying...
We have motorized blinds controlled by Somfy. Would you consider buying a sensor that automatically lowers the blinds at a certain temperature?
Thanks in advance for your replies.
Neues zweistöckiges Haus auf Baustelle mit weißer Blockfassade, pinker Dämmung und großen Fenstern
Daniel-Sp
18 Dec 2019 08:05
Well done with the float!
Could you please post a table like the one from Monday again?
bortel
18 Dec 2019 08:07
You are way too restless... with the temperatures outside, everything is all mixed up anyway. It needs to get colder so you can properly balance the system.
Daniel-Sp
18 Dec 2019 08:11
You can still carefully work on the thermal balancing of the rooms.
chewbacca12318 Dec 2019 08:36
bortel schrieb:
You’re way too restless... with the outdoor temperature being so unstable anyway.
Yes, I know, but at 22.5°C (72.5°F) in the bedroom at night, it really becomes unbearable.
chewbacca12318 Dec 2019 08:38
Daniel-Sp schrieb:
Good with the float!
Could you please post a table like the one on Monday again?
I'll do that later. I was also able to open the bathroom float a bit more, about half a turn. Let's wait and see. I'll make the table later. But first, I need to eat.
bortel
18 Dec 2019 08:56
Then simply close it off completely in the walk-in closet and bedroom… and if you notice anything, you can gradually adjust it to the desired temperature.
