ᐅ Underfloor heating with an air-to-water heat pump. House gets too warm when the sun is shining.
Created on: 4 Dec 2019 14:18
chewbacca123
I have a general question.
We moved into our new build four months ago. The living area on the ground floor has three large floor-to-ceiling windows facing south. We have underfloor heating and an air-to-water heat pump.
It provides a really comfortable temperature inside the house, but we have a problem – whenever the sun is shining in winter, even if it’s -2°C (28°F) outside, the temperature suddenly rises to 24°C (75°F) in the living room. It gets uncomfortably warm in here, and the underfloor heating can’t be turned down quickly.
Should we assume that the large floor-to-ceiling windows are responsible for the heat gain? A photo of the south-facing side of the house is attached.
What would you do – always lower all the blinds as soon as sunlight is forecast? That seems quite annoying...
We have motorized blinds controlled by Somfy. Would you consider buying a sensor that automatically lowers the blinds at a certain temperature?
Thanks in advance for your replies.
Daniel-Sp17 Dec 2019 08:39My flow tubes have a stop at fully open and cannot be unscrewed beyond that.
More flow in the bathroom?
What setting is the bypass valve on?
By closing it, I was able to achieve more flow, but only gradually turning it at first.
guckuck2 schrieb:
Maybe take a break for a while. It was 10°C (50°F) outside here this morning. At that point, adjusting settings doesn't really help anymore.You’re right, with all my overenthusiasm, I hadn’t really thought about that anymore.Daniel-Sp schrieb:
My flow tubes have a stop at fully open, so they can’t be unscrewed completely.
Closing it allowed me to get more flow, but only adjust it gradually at first. Yes, I was apparently able to unscrew mine completely, and then I took a shower. But only for a fraction of a second—I reacted quickly and screwed it back in.
I’m monitoring the situation now and will report back tomorrow morning, or maybe this evening.
Do you know why I couldn’t give the bathroom more than two? I reduced the supply to the hallway quite a bit, including the parents’ bedroom and the walk-in closet.
Daniel-Sp17 Dec 2019 10:41This is a matter of resistance (pipe length, diameter, bending radius, installation spacing). Heating water also follows the path of least resistance. As I mentioned, I was able to increase flow further by closing the bypass valve.
Daniel-Sp schrieb:
This is a matter of resistance (pipe length, diameter, bend radius, installation spacing). Heating water always follows the path of least resistance. As I said, in my case, more flow was achieved by closing the bypass valve. But can I simply close the bypass valve, even if the individual room thermostats are still installed?
Over the past two days, I have consumed around 30 kWh per day, which is obviously very high.
However, this was likely due to our house becoming extremely warm.
What do you think—how will the kilowatt-hour consumption develop from here? Should I expect improvement by tomorrow?
