ᐅ U-shaped kitchen: How to fill the gap
Created on: 3 Nov 2015 09:30
Spanni
Our Metod has been standing around for a while now... eventually, we need to close the gaps.
Our kitchen is arranged in a U-shape. The long side of course never matches the exact measurement to be completely filled with cabinets. So, there’s always a gap somewhere where a filler strip (I think that’s what it’s called in the planner) should go.
But where can I get one? Ideally, it should be the same color as the cabinet fronts.
And how do I attach it?
Spanni
wolf2000
12 Nov 2015 08:38
... no - I meant: move all the base cabinets about 8cm (3 inches) to the right, then the right one will touch the carousel cabinet and you will only have a gap on the left, which will be closed with a filler panel.
Spanni
12 Nov 2015 11:25
Oh right, hmmm, true, that could have been an option. Now there's the hole for the sink... so it just has to work like this.
wolf2000
12 Nov 2015 12:06
Now there is just the hole for the sink...
That might have been the potential deal-breaker. Is the sink installed in the countertop in such a way that you can no longer move the cabinet? Not every sink fills the entire base cabinet...
Also, reconsider adding a towel holder in the gap:
White wall-mounted towel holder with multiple bars for hanging towels.
Utrusta
Towel rail, white
There are definitely similar options from other manufacturers in the right width.
Alaba
12 Nov 2015 13:43
I would buy a 20 cm (8 inch) door and modify it.
Cut out 12 cm (5 inches) from the middle and glue it back together.
It’s worth trying since the door only costs a few euros.
I don’t know what tools your acquaintance has available. I’ve shortened a Hemnes door like this before, and you can’t see the modification.
Method A:
Trim both parts by 1 mm (0.04 inch) to size. Then put them together, screw them from underneath, and cut across the joint with a plunge saw. After that, you’ll have two perfectly parallel cutting edges. Unscrew it again and use a biscuit joiner to align the surfaces flush.
Method B:
Same principle, but using a router with a guide rail.
Laboe-Klaus
7 Aug 2021 13:32
probably a bit late now, but maybe this helps others:
IKEA assumes that you make "filler strips" to cover small gaps from IKEA "side panels." This actually works quite well, but the side panels are not as thick (about 15 mm (0.6 inch)) as the fronts (about 19 mm (0.75 inch)), although that doesn’t bother me. The side panels come in every front color.
So cut them carefully (always use a guide rail for the circular saw and keep in mind that one side will splinter while the other stays clean, so do tests!). I painted the cut edges with matte paint RAL 9001, because I have Bodbyn front panels in light ivory. The color matches perfectly. The filler strips were then glued on, for example, with construction adhesive.
I am very satisfied with this.
