ᐅ Two-family residential house
Created on: 18 Dec 2016 12:07
Bergziege29
I would also like to share my design here for discussion. The design was created by me and complies with the development plan. I am preparing the building application myself. However, since I am "only" a civil engineer, I am hoping for input or suggestions for improvement and optimization.
Plot size: 819 m² (8807 sq ft) + 261 m² (2810 sq ft)
Slope: yes, about 0.50 m (20 inches) from front to back
Roof type: hipped roof with trusses
Style: modern
Basement: no
Floors: ground floor + attic tower
Number of occupants: residential unit 2: retirees, residential unit 1: 2 adults, 2 children (teens)
Open architecture
Modern construction method: yes
Number of dining seats: 6
Fireplace: yes
Garage, carport: 1 garage, 1 carport
Who created the design:
- Do-it-Yourself
What do you particularly like? Why? The building line and floor area ratio are predetermined; the plan was to create 2 single-story units. I like my design but would appreciate outside opinions as it might lack creativity.
What do you dislike? Why? The bathrooms are not yet optimal.
Preferred heating system: underfloor heating, heat pump with ground collectors
If you had to give up something, what details or expansions would you skip?
Nothing 🙂
Thanks and best regards
19 Dec 2016 08:55
Bergziege29 schrieb:
Sorry, this is not meant to be sugarcoating; I’m very interested in any feedback because I’ve started to develop tunnel vision. It would be great if some improvement ideas could be shared as well.
Thanks and regards]
Sorry, but adequate is close to insufficient.
A wardrobe planned at 60 cm (24 inches) depth is good; some wardrobes with doors measure nearly 65 cm (26 inches). This applies to main closets as well as wardrobes. You can fudge a bit by using 50 cm (20 inches) units without doors. We have those too, but the storage underneath is unsatisfactory.
Passing through the chill lounge with your shopping bags to get to the kitchen. There should also be situations where you want to retreat without immediately going to bed – which is not possible here. The 52 m² (560 sq ft) are somewhat overstated, since the first part actually still belongs to the hallway.
And yes, people often rationalize their own blind spots – frequently comparing the present with the past 😉
tomtom7919 Dec 2016 11:20
This floor plan and your implementation are probably final, with no more changes expected.
But you really should reconsider.
PS. The bedroom is located next to the hallway of the main apartment, so if someone is a bit loud in the evening, everyone in the bedroom will be disturbed.
Bergziege29
19 Dec 2016 20:46
Alright, so I’m going to try the following:
- Swap the living room and kitchen (although I really liked the south-facing side 🙁, and my kitchen is almost new and 4.18 m long (13 feet 9 inches), so it should actually stay like that).
The chimney will also move because of this; we’ll see where it ends up.
- Plan cabinets with a depth of 60 cm (24 inches) or declutter more (so fewer cabinets will be necessary).
- Make the hallway smaller.
- Make the bedroom and closet larger—hmm, does that mean the small tower room should be bigger too?
- Check how much accessibility I can still incorporate into Apartment 2.
@TomTom: maybe you have some constructive input? How much should I scale back? I haven’t submitted the building permit / planning permission yet; otherwise, I wouldn’t be asking. You don’t really find the bedroom next to the entrance hallway problematic, do you? 🙂 Otherwise, most multi-family buildings would have to be redesigned.
So, any thoughts on the exterior appearance?
Thanks a lot and have a great evening!
tomtom7919 Dec 2016 20:59
And yes, I’m serious. In semi-detached houses, different partition walls are definitely installed, and in typical multi-family houses, the doors are located centrally at the staircase, and hopefully, there won’t be a bedroom there.
And I think that’s a good point, but you probably don’t like hearing it, just like your 40cm (16 inches) cabinet...
Have a good evening, I’m out.
19 Dec 2016 21:30
Have you considered placing the private rooms in the north/west? Usually, as you get older, stronger sunlight in living areas is less desirable. So you might want to swap those areas if possible.
Climbee20 Dec 2016 11:41
I also don’t think the design is ideal, but a quick note on wardrobe depth:
You need 60cm (24 inches) if you want to hang clothes. However, if you only plan to store T-shirts, sweaters, etc. folded, 45cm (18 inches) is sufficient (and, in my opinion, even more practical).
The kitchen doesn’t necessarily have to be relocated, but it might be better designed so that the passageway is within the kitchen area, not the living area (for example, move the wall toward the living area according to the plan, shift the door upward on the plan, so it opens into the kitchen).
Is a basement planned?
Overall, including a potential basement, there is very little storage space. This needs improvement! You won’t want to have to run through the hallway to the utility room every time you need the vacuum cleaner.
Statements like “we have it like that now and it’s enough” really annoy me and discourage me from contributing. That kind of attitude is unacceptable, sorry. You are building your house and investing a lot of money, so a “that will do” approach is simply not enough. At least that’s how I feel.
A 40cm (16 inches) deep coat niche can work in a pinch, but it’s not ideal. So consider planning it differently.
